wondering if anyone has any ideas car will idle at around 600rpm and will idle at 1500 rpm anywhere inbetween it hunts up and down. I've pressuresised the system there are no vacume leaks changed fuel pump fuel filter and fuel regulator and no change also when it's hunting it's going lean and putting fuel in those areas doesn't help
it's not a air leak as I have pressurised the intake system and there is no leaks. the map areas were it's hunting I've added fuel removed fuel added ignition removed ignition nothing helps could crank sensor or cam sensor gap cause this sort of issue
had a play with it today closed the gap on the cam sensor and played with a few settings and it now idles as it should. thanks for all the help and suggestions
