4x4 gearbox oil change
When Bara did mine i asked him same and he did advise me that i can use Motul gear 300 both in box and transfer case or atf also in transfer case yet i did in past use atf fluid with no problem..Only what i noticed when using atf that is is a bit noisy..
you need to run the proper mt75 oil, think it's been discontinued by ford though as they just specify whatever they are selling now for boxes
the shifts are much improved with the correct oil
Is this a diy job on axel stands in the garage or up on a lift effort.
Need to check my level on the gearbox and top up if required.
Any pics of the plugs/level checking points.
(4x4 j plate Sapp)
sorry to hijack your post but it might help us both.
(4x4 j plate Sapp)
pete mcrash
70
Oct 21, 2007 08:00 AM
coswol
Apr 19, 2007 12:39 PM
Gra
Aug 11, 2006 11:27 AM
spadey
May 5, 2006 11:00 AM
