how hard to change the gearbox oil on a 4x4 saph box?
my Gearbox drian plug needs to be replaced, so how hard is it to replace or top up the gearbox oil? as obviously removing the plug will let all the currrent oil do a bid for freedom
Originally Posted by Gra
my Gearbox drain plug needs to be replaced, so how hard is it to replace or top up the gearbox oil? as obviously removing the plug will let all the currrent oil do a bid for freedom
Passenger side view (on RHD cars anyway lol) shown.
Note that there is a gearbox "half" and a transfer box "half".
A = GEARBOX fill point, use gear oil EP 75/90
B = GEARBOX drain point.
C = TRANSFER BOX fill point, use ATF (auto transmission fluid).
D = TRANSFER BOX drain point (can only be seen on pics 3 & 4).
![](https://img.photobucket.com/albums/0803/stirling/MT-751.jpg)
![](https://img.photobucket.com/albums/0803/stirling/MT-752.jpg)
![](https://img.photobucket.com/albums/0803/stirling/MT-753.jpg)
![](https://img.photobucket.com/albums/0803/stirling/MT-754.jpg)
arent you spose to use MT75 gear oil on an mtx75 box??
also do you just fill it up to the fill hole, and thats the level? or is there a precise amount?
Slowpoke, yes the plugs can be reused many times.
When checking fluid levels should make sure the car is "fairlt" level, so you need 4 axle stands idealy. Car must be secure on the axle stands so that it cannot slide off......as most of your body will be under the car for this job.
Gear box fill level is to the bottom of the fill hole, so basically as it starts to overflow put the plug back in.
Transfer box correct fill level is 16 - 18mm BELOW the bottom of the fill hole, so use a right angled allen key as a dip-stick, poke it through the fill hole to check for the correct level.
mrmann
20-08-2015 11:24 PM
