4x4 gearbox oil change
Can I replace the 4x4 gearbox oil with an ATF fluid or does it have to be an MT75 fluid? Many thanks Matthew |
Forgot to mention the box has been rebuilt so I don’t want to put the wrong oil in it |
When Bara did mine i asked him same and he did advise me that i can use Motul gear 300 both in box and transfer case or atf also in transfer case yet i did in past use atf fluid with no problem..Only what i noticed when using atf that is is a bit noisy..
you need to run the proper mt75 oil, think it's been discontinued by ford though as they just specify whatever they are selling now for boxes
the shifts are much improved with the correct oil |
Is this a diy job on axel stands in the garage or up on a lift effort.
Need to check my level on the gearbox and top up if required. Any pics of the plugs/level checking points. (4x4 j plate Sapp) sorry to hijack your post but it might help us both. |
Level on stands is easy job but be safe |
Safety first always....
Do I need to come at it from the n/s or o/s obviously from underneath. |
there's a drain plug at the bottom and a filler plug further up, on the side, the centre diff needs it's only oil supply
using Mobil 1 75w90 fully synthetic, cant remember where or who, but was told this was the best stuff to use
Fuchs Titan race synchro 75/90 in my one was told good to use by Pete Dougherty |
© 2024 MH Sub I, LLC dba Internet Brands
