Cosworth rocker cover reburb colour
Old Jul 27, 2018 | 02:46 PM
Russ6334's Avatar
Russ6334
Default Cosworth rocker cover reburb colour
hi all
my cossie rocker cover has been either polished or sprayed silver need to take a better look but as a K plate I believe it should be green
is this a simply case of spraying green and sanding down the top or is it powder coated?
also anyone know the green colour or code etc?
thanks
russ
Old Jul 27, 2018 | 03:37 PM
Caddyshack's Avatar
Caddyshack
Most of the time they are painted and then sanded or milled back.
Old Jul 27, 2018 | 10:40 PM
Matty_C's Avatar
Matty_C
10 Year Member
Colour code I used for mine was Fiat 312 b aero basecoat
Old Jul 28, 2018 | 12:46 PM
Russ6334's Avatar
Russ6334
Any ideas how to ID the cover using the vin plates etc?
im certain as a Sierra 1993 K it should be a green top but looking at the sanded cover there is evidence of blue which I always thought was escort?
Remnants of blue paint
Old Jul 28, 2018 | 03:44 PM
costina's Avatar
costina
Live long and prosper!!
If you have a 02 sensor then it's green if you have not it's blue.
And to add early 4x4's was red.....
escorts are all blue.
Confused now eh....
Old Jul 28, 2018 | 03:47 PM
Russ6334's Avatar
Russ6334
Where would I find the o2 sensor? On the down pipe? I should I believe have a cat but I don’t but nothing to say someone hasn’t removed it but it’s always passed MOT (but that means nothing)
Maybe it should be blue then?
there is a sensor post turbo literally 2” behind the turbo
is that the 02 sensor?
Old Jul 28, 2018 | 04:00 PM
costina's Avatar
costina
Yes it's actually in the turbo exhaust housing as std.
Old Jul 28, 2018 | 04:01 PM
costina's Avatar
costina
Pics would help
Old Jul 28, 2018 | 04:04 PM
Russ6334's Avatar
Russ6334
Just at a bbq but this is zoomed from an old photo
not exactly clear will put another up later
Old Jul 28, 2018 | 04:08 PM
costina's Avatar
costina
Yep that's it.
see you have a 34mm restrictor on it.
So my thoughts it should be green being on a K plate.
But I like blue better.
Old Jul 28, 2018 | 04:13 PM
Russ6334's Avatar
Russ6334
I like blue better as well but you can guarantee when you sell it you will get there “ere mate it’s got the wrong head on it it must have been written off blah blah blah I’ll give you Ł10k less!!!!”
Old Jul 28, 2018 | 04:21 PM
costina's Avatar
costina
I would not worry about what other people think or say.
If you like blue then blue it should be.
I have a nice blue I picked.
Old Jul 28, 2018 | 04:29 PM
Russ6334's Avatar
Russ6334
What paint did you use? Halfords have some similar blues but said it won’t stick but when I check YouTube everyone is spraying with aerosols
Old Jul 28, 2018 | 04:30 PM
costina's Avatar
costina
Old Jul 28, 2018 | 04:34 PM
costina's Avatar
costina
I have used many over the years that blue one was painted in 2k.
one that's on my car was painted about 9 years ago with Halfords Rosso red.
You need it fully decreased and keyed up or gently blasted.
I have NEVER used primers.
Old Jul 28, 2018 | 04:38 PM
Russ6334's Avatar
Russ6334
My dad has a sand blaster
I’ll give the blue from Halfords a go then
enamel or normal? Or the high temp stuff? Do you know the exact colour you used from halfords
Old Jul 28, 2018 | 04:43 PM
costina's Avatar
costina
Only the rosso red one.
But any normal Halfords paint will be fine.
mask up the raised area prior to blasting and do it at low pressure just to key the surface.
Then mask the raised areas this saves time flatting the paint back to bare alloy. You can do the lettering with a brush just spray the paint into the lid.
Old Jul 28, 2018 | 05:52 PM
qed296's Avatar
qed296
Mine done just a few months ago.....J plate 4x4
powder coated then polished.
Just check there's enough material left on the top to be machined back again.
I had one that had no depth so was just painted and left all one colour.
Old Jul 28, 2018 | 05:56 PM
Russ6334's Avatar
Russ6334
V. Jealous looks nice, I wish mine was more standard everything is polished alloy on mine looks like a 16 year old that’s found Elizabeth duke at Argos!
Old Jul 28, 2018 | 06:01 PM
qed296's Avatar
qed296
Thats how mine started of, but when it was done like that it was the in thing. Not my cuppa tea but i do appreciate other people's for the work, time and effort to achieve it.
Old Jul 28, 2018 | 08:34 PM
Thrush's Avatar
Thrush
Irritating c........
Why were there blue, red and green ones?
Old Jul 28, 2018 | 08:45 PM
qed296's Avatar
qed296
Green ?? was a nod to being eco friendly as it had cats fitted to comply with emissions.ybg
red ?? 3dr ybb
rs500 ybd
2wd sapphire ybb
4wd sapphire early model (different engine code)ybj
blue ?? Escort Cosworth ybt
think that's correct.....
Old Jul 28, 2018 | 09:46 PM
cossynut2's Avatar
cossynut2
10 Year Member
Everyone has different tastes as to how they want their engine bay to look, the standard look has never been to my liking and I prefer the shiny look. Anyone that would make a big fuss about you not having the "correct" colour rocker cover would not bother me one bit. My engine bay which suits me fine!
Old Jul 29, 2018 | 07:00 AM
Russ6334's Avatar
Russ6334
And it’s blue!!!!
sod it mines going blue then!
Old Jul 29, 2018 | 07:02 AM
Caddyshack's Avatar
Caddyshack
Not sure I would sand blast one as never certain you have all the sand out and wouldn’t want that in my oil. I had mine vapour blasted.
good paint suppliers can make up rattle cans, they are much better quality.
Old Jul 29, 2018 | 08:09 AM
cossynut2's Avatar
cossynut2
10 Year Member
Not sure what paint mine has on it but 22 years after it was done it still looks good!
Old Jul 29, 2018 | 09:02 AM
Russ6334's Avatar
Russ6334
any idea on the colour? Halfords do a few but want as close to original as I can
Old Jul 29, 2018 | 09:38 AM
costina's Avatar
costina
Trick is to only blast the top. At work we use glass beads to do a lot of alloy parts but again only the outside.
Vapour blasting is good but not many people do it so you either have to post or travel which is a pain.
Another way I have stripped one is with paint stripper and a brass brush which can make a mess.
Old Jul 29, 2018 | 10:42 AM
qed296's Avatar
qed296
Don't hold me to it but I have this scribbled down :
PAINT CODES :
RAL 5002 BLUE
RAL 3020 RED
Old Jul 29, 2018 | 10:54 AM
james kiely's Avatar
james kiely
i need to paint a 3dr rocker cover so if someone could confirm that ral for the red i would be greatful
Old Jul 29, 2018 | 11:04 AM
qed296's Avatar
qed296
Lifted from escortrscosworth.com
Old Jul 29, 2018 | 11:06 AM
costina's Avatar
costina
That blue is a little darker than mine.
Old Jul 30, 2018 | 02:22 PM
Russ6334's Avatar
Russ6334
PAINT CODES :
RAL 5002 BLUE
RAL 3020 RED
ordered some blue paint using the code above I’ll put a photo on when done
Old Jul 31, 2018 | 08:24 PM
Russ6334's Avatar
Russ6334
Well painted it today with RAL 5002 as suggested, looks a bit darker? But have to bake it on bbq tomorrow! Hahah
Old Jul 31, 2018 | 08:35 PM
Russ6334's Avatar
Russ6334
Next question though
lacquer?
Old Jul 31, 2018 | 08:50 PM
qed296's Avatar
qed296
Taking into account light, camera etc etc it looks good....remember though once it's flatted back and you have the contrast of the shiney bits it will change how it looks. (The eyes are a funny thing!!)
I've lacquered and not, with mixed results....my best attempt wasn't lacquered.
Old Aug 1, 2018 | 06:19 AM
Russ6334's Avatar
Russ6334
Looks better this morning. I heated it up with a 1kw heater before I painted it and tonight after 24hrs I will tinfoil the hell out of my gas bbq and put it inside for 1.5 hrs at 150 degrees hopefully that should bake it as I’ve seen online suggestions
in the morning light -
Old Aug 1, 2018 | 10:23 AM
costina's Avatar
costina
I have never used clear coat.
Old Aug 1, 2018 | 09:38 PM
cossynut2's Avatar
cossynut2
10 Year Member
lacquer?
The paint is now completely dry and cured, are you going to polish it to a high gloss finish or leave it as a matt finish? I prefer the rocker cover shiny myself.
Old Aug 2, 2018 | 06:53 AM
Russ6334's Avatar
Russ6334
probably leave it as is because I don’t see how you could get an even polish as so many parts are awkward to get to
