Cosworth rocker cover reburb colour
hi all
my cossie rocker cover has been either polished or sprayed silver need to take a better look but as a K plate I believe it should be green
is this a simply case of spraying green and sanding down the top or is it powder coated?
also anyone know the green colour or code etc?
thanks
russ
thanks
russ
Most of the time they are painted and then sanded or milled back.
Any ideas how to ID the cover using the vin plates etc?
im certain as a Sierra 1993 K it should be a green top but looking at the sanded cover there is evidence of blue which I always thought was escort?
Remnants of blue paint
Where would I find the o2 sensor? On the down pipe? I should I believe have a cat but I don’t but nothing to say someone hasn’t removed it but it’s always passed MOT (but that means nothing)
Maybe it should be blue then?
there is a sensor post turbo literally 2” behind the turbo
is that the 02 sensor?
I like blue better as well but you can guarantee when you sell it you will get there “ere mate it’s got the wrong head on it it must have been written off blah blah blah I’ll give you Ł10k less!!!!”
What paint did you use? Halfords have some similar blues but said it won’t stick but when I check YouTube everyone is spraying with aerosols
My dad has a sand blaster
I’ll give the blue from Halfords a go then
enamel or normal? Or the high temp stuff? Do you know the exact colour you used from halfords
Live long and prosper!!
Only the rosso red one.
But any normal Halfords paint will be fine.
mask up the raised area prior to blasting and do it at low pressure just to key the surface.
Then mask the raised areas this saves time flatting the paint back to bare alloy. You can do the lettering with a brush just spray the paint into the lid.
Mine done just a few months ago.....J plate 4x4
powder coated then polished.
Just check there's enough material left on the top to be machined back again.
I had one that had no depth so was just painted and left all one colour.
V. Jealous looks nice, I wish mine was more standard everything is polished alloy on mine looks like a 16 year old that’s found Elizabeth duke at Argos!
Thats how mine started of, but when it was done like that it was the in thing. Not my cuppa tea but i do appreciate other people's for the work, time and effort to achieve it.
Green ?? was a nod to being eco friendly as it had cats fitted to comply with emissions.ybg
red ?? 3dr ybb
rs500 ybd
2wd sapphire ybb
4wd sapphire early model (different engine code)ybj
blue ?? Escort Cosworth ybt
think that's correct.....
red ?? 3dr ybb
rs500 ybd
2wd sapphire ybb
Not sure I would sand blast one as never certain you have all the sand out and wouldn’t want that in my oil. I had mine vapour blasted.
good paint suppliers can make up rattle cans, they are much better quality.
Everyone has different tastes as to how they want their engine bay to look, the standard look has never been to my liking and I prefer the shiny look. Anyone that would make a big fuss about you not having the "correct" colour rocker cover would not bother me one bit.
My engine bay which suits me fine!
Vapour blasting is good but not many people do it so you either have to post or travel which is a pain.
Another way I have stripped one is with paint stripper and a brass brush which can make a mess.
james kiely (29-07-2018)
Taking into account light, camera etc etc it looks good....remember though once it's flatted back and you have the contrast of the shiney bits it will change how it looks. (The eyes are a funny thing!!)
I've lacquered and not, with mixed results....my best attempt wasn't lacquered.
Looks better this morning. I heated it up with a 1kw heater before I painted it and tonight after 24hrs I will tinfoil the hell out of my gas bbq and put it inside for 1.5 hrs at 150 degrees hopefully that should bake it as I’ve seen online suggestions
in the morning light -
