Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
coolant bubbling
Old Jul 12, 2018 | 02:52 PM
fixanycar's Avatar
fixanycar
Default coolant bubbling
Hi ford focus (2005) mk2, ( pre-facelift) 1.6 petrol.
Had a leaking heater matrix, which is now done, not a nice job!
Now when you run it up, get warm air in car fine, car runs up & fans kick in. But keep getting boiling inside the expansion tank, temp gauge stays normal.I have since replaced the thermostat & now on idle it is ok, a few bubbles just as the fan kicks in but nothing serious, however if you run it with the cap off then it boils over when the fans kick in, stops when the fans stop. Just taken it for a 20 mile drive, performed as you would expect but again boiling inside the expansion tank and the pressure cap ( which is brand new, 2nd 1 in case 1st was faulty) releases & then coolant leaks on the ground.
Any ideas people?
Old Jul 12, 2018 | 07:36 PM
RichieST's Avatar
RichieST
It will boil with the cap off. Sounds like head gasket, needs a sniff test to see if it's exhaust gases.
Old Jul 13, 2018 | 05:36 AM
fixanycar's Avatar
fixanycar
Have done sniff test & cylinder leakage test, both passed fine
RSRoy
May 13, 2009 02:46 PM
daviddunlop83
Jun 30, 2006 08:58 PM
MATCOS
Ford Escort RS Cosworth
13
Jun 5, 2006 07:50 PM
nzcossie
Dec 26, 2004 06:43 PM
Gadget
33
Jul 21, 2004 05:59 PM
