Overflow tank bubbling on sapph cossie
After a run the Overflow tank is really hot and bubbling , temp gauge is as normal .
Testing the future
that's normal, it's mostly water coming back through the turbo water return and as the turbo and manifold were so hot and are bloody great lumps of steel, they hold enogh heat to boil the water for a good while.
presumably the last 10 minutes before switching off you drive the car without boosting, or let it idle a while to cool the turbo a bit before switching off?
it's important to cool the turbo by water, otherwise the oil that's in the plain bearing on the turbo shaft can become burnt on and redce the life.
DavidK
27-09-2015 02:55 PM
