Hi Spec handbrake calipers
Old Apr 20, 2018 | 06:44 PM
timsrs's Avatar
timsrs
Default Hi Spec handbrake calipers
I’m looking for a four pot rear caliper with handbrake mechanism
I have seen hi spec used to do a nice kit
It’s for a 2WD Sapphire Cosworth
Has anyone got a kit for sale or what are they running on the rear of their cars or can advise
Compbrake do a kit but heard bad things with quality of their kits
Thanks guys
Old Apr 20, 2018 | 09:32 PM
jason_nike's Avatar
jason_nike
I have a Hi Spec rear brake setup with handbrake mechanism.
Just need to fit it.
Can post pics of them if it helps for reference
Old Apr 20, 2018 | 09:39 PM
timsrs's Avatar
timsrs
Yeah
Don’t want yo sell them do you 😀😀
Old Apr 21, 2018 | 06:48 AM
Marc sierra's Avatar
Marc sierra
I have the standard 4x4 calipers with a 325 mm conversion set from Reyland at the rear. Multiple piston calipers look nice, but imo there not really needed at the rear. You should also take care that the rear is not overbraked.
Old Apr 21, 2018 | 10:42 AM
timsrs's Avatar
timsrs
Yes completely understand where your coming from
If I go this route I’ll be running 6 pots on the front as to balance the braking out
Old Apr 21, 2018 | 02:14 PM
Marc sierra
Whether they are 6 pots, 4 pots or even single pots doesn’t matter for the braking force. It’s the total piston size combineerde with the disc diameter that matters. I have 4 pots with 356 mm discs at the front, where the total surface area of the 4 pots is equalizer to the surface area of the pistons on the standard calipers.
Old Apr 21, 2018 | 03:43 PM
costina's Avatar
costina
Live long and prosper!!
We use these calipers at work and as a brake they are good but as a emergency hand brake they are shit.
Only good as a parking brake really and suited to lighter cars not a saff.
big discs and std calipers will do you well.
Old Apr 22, 2018 | 08:14 PM
jason_nike's Avatar
jason_nike
Originally Posted by timsrs
Yeah
TBH I keep meaning to fit them, but never seem to get around to doing it
turborob
Apr 26, 2009 04:31 PM
Char1ie
May 18, 2008 06:55 PM
kjc300
Oct 14, 2007 07:56 AM
antony215
Oct 11, 2006 07:19 AM
Niall.b
18
Apr 17, 2006 12:51 PM
