AP Handbrake calipers
who sells these as i think im going the 4 pot route on the rear & cant be arsed with hydraulics
http://www.rallydesign.co.uk/catalog...oducts_id=8312
spoke to martin at reyland regarding these
reckons your best bet is to find a mot friendly tester and use a hydraulic handbrake
have a look at my pics, have some pics off just what you want and evern the brackets that had to be made ect, it was a bit off work to get sorted but it does look once done
Originally Posted by marco polo
Originally Posted by Ryan
indeed they are, spot calipers
with "AP" applied afterwards.
dont tell everyone i told 3 people and now the world knows
Dunc
i used the original brackets that come with the kit and used the same handbrake cable works spot on
Is there a limit on the size of disc you can use with the standard bracket?
max disc diameter is 330 mm & thickness 20.8,
if 4x4 disc is 22mm can you mod the caliper easily or will it squeeze on
Dunc
well to be honest , i don't think so i have 330 x32mm discs on the rear and they are fine
the calipers have spacers so you can alter to suit the thickness of your discs
here is an old pic
[/quote]
marco
