Polishing scratches out of glass
Old Apr 1, 2018 | 05:06 PM
haz87's Avatar
haz87
Default Polishing scratches out of glass
I fear I already know the answer (replace) but given every piece of glass on my car other than the windscreen is affected, i'm hoping for some magic solution as i definitely am not replacing the full glass set .
Basically all my glass has a variety of scractches, a good 50% of which can be felt with the fingernail test (just!).
There are some ridiculously deep gouges that i know wont ever be rid of but im hoping i can bring down some of the shallower ones. I am by far a bufty so dont need a mirror finish, i just want to reduce how much the scratches are standing out and if possible, remove the non-fingernail level ones.
I have tried the normal compounds and got some Cerium Oxide too but found that did little to nothing more than the "off the shelf" compounds.
Have used drill/dremels with a mix of felt pads/wool pads/foam pads so far.
Is this the kind of thing a proper detailler could help with? Or is there something stronger that Cerium available?
Any ideas/suggestions much appreciated!
Old Apr 1, 2018 | 05:39 PM
Adam-M's Avatar
Adam-M
My work use cerium on a soft pad attached to an air drill to remove scratches from glass but depends on how deep it is.
Old Apr 1, 2018 | 05:41 PM
Caddyshack's Avatar
Caddyshack
What is your work, Adam?
Old Apr 1, 2018 | 05:45 PM
Adam-M's Avatar
Adam-M
I’m a maintenance engineer at 3 glass factories mate, they process windows for buses and trains ect, when the operators fuck up and scratch the faces of the glass they polish them out with the above method. I’d expect starting with ultra fine emery cloth and then on to a polish pad may be better.
Old Apr 1, 2018 | 05:50 PM
Caddyshack's Avatar
Caddyshack
Cool, my family business is in glazing, we roll steel in India then ship to our 24hr factory in Poland and then finally on to here. We made an equivalent to the Critall window about 100 years ago.
I always wondered how to get scratches out of glass
Old Apr 1, 2018 | 05:55 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
Cerium oxide is probably the best bet. Make it up into a milk like consistency with water and apply with a felt pad in a drill. Don't run it over 1500 rpm and always keep it wet. It's a slow old process but it does work.
Old Apr 1, 2018 | 06:11 PM
haz87's Avatar
haz87
Sounds like its probably patience on my part then - something i lack with this kind of thing
Old Apr 1, 2018 | 06:13 PM
Caddyshack's Avatar
Caddyshack
Stick a V8 on the end of the polisher. POWER
Old Apr 1, 2018 | 07:43 PM
Adam-M's Avatar
Adam-M
That sounds like a big operation lol
Old Apr 1, 2018 | 09:24 PM
Rsmat's Avatar
Rsmat
Saved me typing ..same as what I do with glass and it takes time and patience .
Old Apr 2, 2018 | 07:58 PM
costina's Avatar
costina
Live long and prosper!!
I work in the car resto trade and most glass is scratched.
As above it takes forever and Will leave you with low spots and will look like your looking through a good fish bowl.
There is no magical solution best to replace.
Old Apr 2, 2018 | 08:10 PM
Caddyshack's Avatar
Caddyshack
Bugger
Old Apr 2, 2018 | 08:15 PM
costina's Avatar
costina
I have done a lot of internet research and some people have used nail varnish to fill deep scratches and then polish flat🤔
Also I have heard that heating the glass to melt to scratches out but would you wanna try it?
Tried for a while to polish number plate etchings out with no joy. My saffs rear screen had a similar issue due to being etched incorrectly and it looks shocking.
paceo
16
Jun 18, 2016 06:35 PM
dissmalrs
Apr 27, 2013 05:14 PM
uyo1972
Concours d'élégance.
Feb 22, 2010 03:32 PM
morcheen
Oct 28, 2009 11:51 AM
Mk3Ghia
Apr 11, 2006 05:13 PM
