ST170 Traction control
Old Mar 2, 2018 | 05:45 PM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
Default ST170 Traction control
Just a quick ask, I know when you turn off the traction control in an ST170 using the button it doesn't really turn it off, which kind of begs the question why is it there ?
Yesterday I drove back in the snow from work, and found the way it cut in really annoying, but it was only when I was trying to move up a slight hill from stand still, with virtually no revs at all, it really annoyed me lol. I figured it would be easier to heat the tyres and melt the ice, but it wouldn't let me lol.
Old Mar 2, 2018 | 08:22 PM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
Would it be possible to wire up a button to the fuse that controls the traction control, so I could press it and cut the fuse ?
Old Mar 3, 2018 | 01:18 AM
GVK.'s Avatar
GVK.
You could do,but as the TC is part of the ABS, then you wouldn't have any brake bias control either, so you end up with rearward bias on the brakes.
Old Mar 3, 2018 | 08:28 AM
PaulinhoT's Avatar
PaulinhoT
10 Year Member
Thanks for the information, I don't really want to be backing the car into corners I wonder if there is an ECU "hack" or override ?
gamekeeper
Ford Focus ST
Sep 13, 2022 05:43 PM
Chris620
Mar 10, 2013 10:55 PM
hump
Nov 10, 2010 01:07 PM
Exeter J
Ford Focus RS
11
Feb 29, 2004 08:14 PM
