Saph cosworth 4x4 clutch cable
Old Feb 18, 2018 | 05:29 PM
Default Saph cosworth 4x4 clutch cable
Hi people.
What is the correct routing/fitting of the clutch cable. At the mo mine comes through the bulk head then it goes down to the steering rack and is secured to the rack then it goes round the engine and to the box.
How were they routed from standard??
Old Feb 19, 2018 | 12:17 PM
martysmartie's Avatar
martysmartie
Mine (2WD) isn't fixed to the rack.
I fitted a replacement and the aftermarket ones have a 'protective' sleeve, this was between the sump and the cross member and it chaffed through the metal PS pipe.
I since repositioned the sleeve.
Martin
Old Feb 19, 2018 | 02:17 PM
Thanks for that. I wonder of 4x4s are the same. There's a gap between the sump and the cross member/sub frame.
Old Feb 22, 2018 | 09:18 PM
4x4kiwi's Avatar
4x4kiwi
Hi Glenn
Cant easily get under to take any photos (tried holding the camera under car and randomly taking photo) but mine comes through the firewall, feeds down between the brake master cylinder and the turbo heat shield, then does a big loop forward where it is zip tied in two places to the cross pipe under the radiator fans (think it may be a heater pipe or something but it is well forward of the steering rack) It then passes inside the engine mount and straight to the hole through the bell housing. I am wondering if yours is a shorter cable (2wd???) as I don't think I would be able to get mine to loop around and attach to the steering rack.
David
Attached Thumbnails Saph cosworth 4x4 clutch cable-cable1.jpg   Saph cosworth 4x4 clutch cable-cable2.jpg   Saph cosworth 4x4 clutch cable-cable3.jpg   Saph cosworth 4x4 clutch cable-cable4.jpg
Old Feb 25, 2018 | 06:30 PM
Thanks for th pics. I think I'm just gonna cable the it back onto the pas pipe again.
Old Feb 25, 2018 | 09:51 PM
dojj's Avatar
dojj
Resident Wrestling Legend
the 4wd version is about 9 foot long mate, it comes out, goes all the wy to the front of the car and then around back underneath again
it's to avoid the heat from the turbo buckling the metal sheathing and collapsing the cable cover
not sure about exactly where the routing goes, but it's that long to avoid the kinks
Old Feb 28, 2018 | 01:44 PM
Yeh there a bloody long cable lol. I've just cable tied it back onto the pas pipe.
Old Mar 7, 2018 | 07:11 PM
Cossy Mike's Avatar
Cossy Mike
Thats were mine is
Old Mar 7, 2018 | 07:13 PM
Cossy Mike's Avatar
Cossy Mike
That's where mine is
Old Mar 7, 2018 | 07:17 PM
That's how I've sercured my cable now.
steventoon
Mar 25, 2011 04:13 PM
steventoon
Mar 22, 2011 04:09 PM
Psycho Warren
Jul 19, 2008 07:35 AM
KSA-Cossie
Nov 20, 2006 09:20 PM
robertlondon
Jul 18, 2006 06:55 PM
