Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
OBD2 Code readers
Old Dec 13, 2017 | 07:01 PM
rmca1988's Avatar
rmca1988
Default OBD2 Code readers
Hi, I have an issue with my car and would be very grateful for your help in helping me diagnose the problem. Can anyone recommend a code scanner for reading engine fault codes on a Mk1 tdci focus (2003 1.8TDCI sport). I borrowed a friends D900 obd2 scanner which turns out to not be compatible. Can anyone confirm if the F Super works on this model or recommend an alternative? Thanks
Old Dec 18, 2017 | 09:35 PM
TrevCos's Avatar
TrevCos
I've got this and it's diagnosed every car I've had it on, don't buy the cheaper Autel units (I did buy a cheaper one previously and it will only look at engine modules), this will literally look at every module on your car (airbag, abs etc etc), and show you any faults in plain English. It's brilliant. Plenty of videos on Youtube too. I've used it on various cars already (Mondeo, Audi TT, MX5 Mk3) and it's worked every time.
My other Autel unit showed no faults on my Mondeo when I knew there was one, it just didn't cover all the systems, make sure you get the version that covers ALL systems.
https://www.ebay.co.uk/itm/UK-Autel-...kAAOSw1QpaDpng
Old Dec 19, 2017 | 12:24 PM
rmca1988's Avatar
rmca1988
Hi Trev,
Thanks for the info. I had to take my car to a mechanic this time to get it plugged in, turned out to be an injector fault. I will have to buy one of these to have for the next time the dash lights up. Thanks again.
Old Dec 19, 2017 | 02:42 PM
TrevCos's Avatar
TrevCos
No problem mate, it sounds a big outlay to start with because obviously you can buy cheaper ones, but they don't do half the things they need to, and use it a couple of times rather than getting charged through the nose for a garage diagnosis and you've paid for it.
Old Dec 19, 2017 | 06:20 PM
studabear's Avatar
studabear
Forscan and lead is cheap on ebay and covers loads. In fact the software is free the modified elmscan lead is about Ł25 on ebay.
Old Dec 23, 2017 | 09:30 PM
TrevCos's Avatar
TrevCos
Depends what you want it for, I bought a cheaper Autel and it does some stuff, but nothing like the amount of stuff I needed to do. Fixed a fault on my father in law's Peugeot 308 today using it. Brilliant tool, there's plenty of cheap ones though if you don't need to cover everything.
Old Dec 23, 2017 | 10:04 PM
GVK.'s Avatar
GVK.
OBD II code readers won't work on pre 2004 diesels.
Cossy Mike
Sep 26, 2013 01:19 PM
andyw77
Ford Focus ST
Apr 28, 2012 07:05 PM
bigal1978
Dec 15, 2005 09:42 AM
fordsportjay
27
Dec 8, 2005 01:57 PM
dannyblackpool
Dec 21, 2004 10:17 PM
