Hi All
I am planning to fit Zetec to my kit car I have the MT75 gearbox at the moment with the DOHC 8V but what fly wheel do I need as this need to match the starter motor as well. I am hoping I can use my present clutch kit , can anyone shed some light over this please?
You can use either the 220mm or the 240mm flywheel. The 2.0 always has the 1" 23 spline clutch. The 220mm could have two differant sizes for the first motion shaft.
You then need either a spacer for the thrust bearing like Westfield or an extended clutch pivot like Gbs.
Starter is from the dohc.
In a 7 with a shorter sump the bottom of the bell housing is going to be around 30mm below the sump. I trimmed mine down.
The 1.8 fly is lighter than the 2.0 but the 2.0 clutch is easier and cheaper to find.
Hi, Forget using fwd clutches and adaptors they do not work very well, either get a 1.8 flywheel re drilled for a pinto clutch or just buy the one from retro-ford. I went with the longer pin to start with and was not happy with it and I understand extended release bearings have a habit of breaking.
As they say there is more than one way to skin a cat. The only wrong way is the one that doesn't work for you.
To say the fwd clutch does not work, well do a search. It works for plenty of people. That's not to say that the rwd isn't better and gives lots of choice for upgrading.
I've never had a problem with the tried and tested fwd clutch. Just play with the clutch pedals pivot points until it feels right.
If you go for 're drilling the fly for a rwd clutch then you will need to play with the thrust bearing as the Westfield bearing and Gbs pivot will be to long and the mt75 bearing will be to short.
The Westfield bearing is a standard mt75 bearing with a 20mm steel spacer glued on. It's not the best engineering practice but neither have i heard of them failing either ?
Any posts on the above ?
Hello, you are correct apart from one thing I did not say that using a fwd clutch etc. does not work as of course it does.
I may be wrong but does the 2.0 flywheel and clutch fit inside the mt75 gearbox? I thought it was only the 1.8 silvertop flywheel that fitted so that is probably the answer to the original question.
Depending on which clutch is chosen, going fwd then buy a used one rwd buy a new one from retro-ford
As for the release bearing would you trust something glued on? the westfield ones may not fail but are very expensive, trying to do it yourself risky I would say.
for safety as well as cost my view is a new flywheel, pinto clutch and capri ct133 bearing, I hope this works as I have removed the fwd clutch arrangement and extended pin and am waiting for some arp flywheel bolts before fitting.
