944 Project begins
Old Jun 5, 2017 | 05:50 PM
Caddyshack's Avatar
Caddyshack
Default 944 Project begins
As my Cossie pug is now near the point of regular use I decided it was time to start on the 944 that has been lurking in my garage for a few years. The engine was shot so I just binned it.
My thoughts for this are to make a cheap track car that I don't care abusing and if I want to do track days, drifting, airfields etc...so that it is cheap to run but not care about too much.
At the moment I am thinking of an Audi 1.8t 20v as these are cheap as chips if I break it and they produce 280 bhp for next to no money and 350 is simple. The best block for this is a 1.8t AEB from an Audi A4 or Passat as these had the block in right orientation and then use part of a Golf MK4 gearbox to hold the flywheel and Mate to an adapter for the torque tube.
My first option was a yank V8 LS engine, much more fun and nice noises but a much more expensive swap.
I have dropped the rear beam out and cleaned it up, removed the torque tube to Mate it up to the new engine.
Old Jun 5, 2017 | 05:57 PM
Caddyshack's Avatar
Caddyshack
Covered in crap, this is now all off
Torque tube
Beam out and getting refurb
Old Jun 5, 2017 | 05:59 PM
jonfoc's Avatar
jonfoc
Here we go again. It's the old this is going to be a quick and cheap project thread. Queue the music A team style. 4 x 4 sequential and 500 horses before you know it
Old Jun 5, 2017 | 06:02 PM
Caddyshack's Avatar
Caddyshack
Lol, everyone teases me about that.....I am really trying to go low budget on this one.
Old Jun 5, 2017 | 06:15 PM
jonfoc's Avatar
jonfoc
Yeah right. I bet you've got a bad taste in your mouth even saying low budget
Old Jun 5, 2017 | 06:22 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Should be a good project looking forward to seeing it take shape. Always liked 944's
Old Jun 6, 2017 | 01:34 AM
visa_broke's Avatar
visa_broke
10 Year Member
glad to see your finally starting on this.
I'm still keeping an eye out for one and will most likely go for a 1.8t conversion.
What are your plans for the sump?
Old Jun 6, 2017 | 06:13 PM
Caddyshack's Avatar
Caddyshack
I am going to prob use a tin sump off a diesel golf so that I can cut and shut it myself but won't rule out sending an ally one to MK and ask him to cut it and add wings. I have sourced the 1.8t today that is aeb which has the oil pump at the right end and is drive by wire. Gearbox from MK 4 golf will arrive this week so can cut up the bits I need to make the adapter and then use g60 flywheel and a vr6 clutch. Then just need to make a simple adapter plate to the MK 4 bellhousing. The gearbox will be a normal 944 box on the end of the torque tube, I have dropped the knackered box out and it is just a Vw gearbox, same as an early Passat, it just sits at the back so I may even use a Passat 6 speed box and add a slippy diff.
Old Jun 6, 2017 | 08:29 PM
jonfoc's Avatar
jonfoc
Yep that's a low budget right there!
Old Jun 6, 2017 | 08:44 PM
jonfoc's Avatar
jonfoc
Double post apologies
Old Jun 6, 2017 | 08:57 PM
Caddyshack's Avatar
Caddyshack
Costs so far....new gearbox Ł39 eBay, bought tonight. Torque tube Ł50 delivered eBay. Mk4 golf gearbox Ł10.91 ebay. Aeb engine price tbc, good mate has it on a pallet, he will do a good deal. (Guess Ł300-Ł500?)
Car cost me Ł1000 2 yrs ago.
Engine loom will be Ł200 for a mate to make as new, Ł30 immobiliser delete on ecu and the maybe Ł300 to remap when I change a few things such as ko4 turbo etc..
I don't think I am doing badly
Old Jun 6, 2017 | 09:01 PM
Caddyshack's Avatar
Caddyshack
I will wait for a cage to come up on eBay, my interior will sell and pay for some bucket seats.
I will allow a bit for service items such as new shocks and brake pads and then consider a few squids on lightweight bonnet, Lexan glass replacement inc rear hatch.
Ford sharan clutch can be used over lightweight mk4 golf flywheel, my friend can supply for Ł150. He is also a pro flex agent so can poly bush reasonably enough.
Old Jun 6, 2017 | 09:10 PM
jonfoc's Avatar
jonfoc
Alright alright you win!
Old Jun 6, 2017 | 09:11 PM
Caddyshack's Avatar
Caddyshack
well, it isn't finished yet.
Old Jun 6, 2017 | 11:16 PM
COLEYST200's Avatar
COLEYST200
Good to see you have started on this old girl
Old Jun 8, 2017 | 01:30 AM
visa_broke's Avatar
visa_broke
10 Year Member
surprised you've not finished this yet
and moved onto stage two
Old Jun 8, 2017 | 09:44 AM
Caddyshack's Avatar
Caddyshack
Thanks for the comments, some are useful LOL. Work gets in the way.
Yesterday I jumped in the car with a Sandwich at lunchtime and drove 1.5hrs to brighton to pick up the 5 speed gearbox, It was Ł39. The bloke was a 911 Trader but had taken in 2 944's as part chop and broke up one for spares and sold the other. He had just done a 1.8t swap in a Passat and had also been looking at the swap in a 944 (small world eh?)
Cleaned up the box last night after work and it does look pretty good, he said the car it came from was rotten from being near the sea but had not done big miles.
This weekend I am going to bolt the torque tube to the box on axle stands and try to make a stable and level platform so that I can offer up the 1.8t block dead level to then start marking out the adapters. The Mk4 golf box will be here soon so I can strip that for the part I need and offer it up.
Old Jun 8, 2017 | 10:21 AM
Rsmat's Avatar
Rsmat
Nice build ..keep it up .
Old Jun 8, 2017 | 10:22 AM
ajamesc's Avatar
ajamesc
Mate Of mind has a modded 1.8T cupra track car. It's only about 280bhp but go's really well
Old Jun 8, 2017 | 11:28 AM
Caddyshack's Avatar
Caddyshack
Yeah, 280bhp is good on a track car. The 944 in my spec was 1180kg from the factory but you can save a ton of weight by taking out the Electric seats (one is pretty lumpy to lift) and then replacing that huge rear glass with Lexan along with a light bonnet and just strip the interior. I saved 100kg on my 911 when I had it and stripped it out and put a pair of light Recaro's in there.
I am hoping to get close to the ton on this one and maybe 300bhp for now, 300 per ton puts it up there with an Audi R8 V10.
Old Jun 9, 2017 | 11:35 PM
visa_broke's Avatar
visa_broke
10 Year Member
You want one of these rear screens, I don't think they are making them anymore which is a shame, looks good.
Should go bloody well at that power/weight.
Old Jun 10, 2017 | 12:36 PM
Caddyshack's Avatar
Caddyshack
I love that screen!
I opened the oil drains on the new box and it has had a change recently I think as they came out very easily, will put new oil in anyway. I cleaned it up and gave it a lick of paint.
Old Jun 11, 2017 | 12:59 AM
visa_broke's Avatar
visa_broke
10 Year Member
thats going to look good underneath the car, you should be able to see that from behind.
I quite like that rear screen, I wonder if anyone makes/sells them
Old Jun 11, 2017 | 10:05 AM
james kiely's Avatar
james kiely
looking forward to updates on this toby.
im with jon on the cheap bit though ,no such thing by the time its finished lol
Old Jun 11, 2017 | 11:36 AM
Caddyshack's Avatar
Caddyshack
These will be counter sunk and next plate bolts up to this one.
Old Jun 11, 2017 | 02:25 PM
Caddyshack's Avatar
Caddyshack
5 speed Box mated up to the torque tube
Ready for MK4 golf bellhousing other end now
Old Jun 11, 2017 | 02:27 PM
Caddyshack's Avatar
Caddyshack
Stone chipped the rear arches to tidy them up
Old Jun 11, 2017 | 02:29 PM
Caddyshack's Avatar
Caddyshack
Fitted a Porsche approved lightweight battery to this Club Sport, weighed 5 kilos and had to make a new clamp for the battery, 10,500 miles from<br/>New in 1989, only about 30 came to U.K.. quite nervous working on it as just valued at Ł220k it is minty mint.
Sadly not mine, it is in a friends collection
Old Jun 16, 2017 | 04:45 PM
Caddyshack's Avatar
Caddyshack
O2j gearbox arrived yesterday Ł10 off eBay and free delivery, have started to strip it ready to make the adapter plate.
Old Jun 16, 2017 | 05:25 PM
Adam-M's Avatar
Adam-M
Very interesting project I'll keep an eye on it
Old Jun 16, 2017 | 05:45 PM
rooos's Avatar
rooos
yeah, agree. another mad plan by CaddyShack...can't miss it .
gonna watch and learn, me too...
looks like a you've made a good start with it .
keep us posted mate...
Old Jun 16, 2017 | 07:15 PM
Caddyshack's Avatar
Caddyshack
Thanks guys, looking forward to driving it again, the 944 is a great car to drive.
Old Jun 17, 2017 | 06:49 AM
mattxr3i's Avatar
mattxr3i
great project and should go really well. Keep the updates coming
Old Jun 17, 2017 | 04:55 PM
Caddyshack's Avatar
Caddyshack
O2j gearbox from mk4 golf, split apart and removing diff and gearset.
This is the machined flat surface that we are after to mount first part of adapter plate to but I don't need the diff end.
So I have roughly cut off the bit I don't need. You can see that I will retain the hole where the hydraulic clutch actuator goes.
I might cut off the extra bolt hole to make it neater as I am sure I don't need it. This is now very light.
Needs a good clean up but now I have my bellhousing to bolt up to the 20v turbo, I will not use the dual mass flywheel, instead I will put on a lightened and balanced g60 Vw flywheel as my mate can buy them trade. The Ford clutch from<br/>The people carrier thingy works on this and uses the Vw hydraulic clutch push. Just need to make the other part of the adapter plate template on Sunday now.
Old Jun 18, 2017 | 01:01 AM
cutch's Avatar
cutch
Series 1 4x4 cossie
Your a glutton for punishment aren't you! Always fancied a wee 944.
Old Jun 18, 2017 | 03:21 PM
visa_broke's Avatar
visa_broke
10 Year Member
good progress, keep me updated please.
I had a look on ebay but couldn't find any listings saying 02j for the box. What engines do these come fitted to and i'll get hold of one.
Old Jun 18, 2017 | 06:42 PM
Caddyshack's Avatar
Caddyshack
Any mk4 golf. I used a diesel one but as we only need the housing any will do. Try and get one with the hydraulic slave included as you need that anyway. You can sell on the shifter part as people in the Vw world upgrade earlier cars with them.
02j is 5 spd. O2m is 6 but they all have other codes. Loads on there for Ł50 but I waited for an auction and Ł10 was a bargain
Old Jun 18, 2017 | 06:50 PM
Caddyshack's Avatar
Caddyshack
If you expand this you can see the 02j code.<br/>
Mk4 golf or any other front wheel drive 1.8t gearbox in 5 speed has it.
Old Jun 18, 2017 | 06:59 PM
Adam-M's Avatar
Adam-M
I take it this model of Porsche originally had a rear mounted gearbox? I know nothing about them
Old Jun 18, 2017 | 07:10 PM
Caddyshack's Avatar
Caddyshack
Yeah, I am not changing the rear gearbox layout. The handling of the 944 was often regarded as one of the best balanced sports cars as it has 50/50 weight due to the gearbox being at the back, it has always been a Vw box at the end of a torque tube, I am only using the bellhousing off the mk4 to contain a flywheel and clutch at the front and make the adapter, nothing different to how Porsche did it, the rear 944 bellhousing is empty on the originals.
