Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
Help please! Cortina headlining
Old Aug 2, 2016 | 08:47 PM
Mattcortina's Avatar
Mattcortina
Default Help please! Cortina headlining
Hi, I am in the process of fitting my mk2 cortina up after paint. I have a new headlining ( there wasnt one fitted when I got the car) and therefore I have absolutely no idea how to fit it up!
I have the bars and it's pretty self- explanatory that these fit in the slots on the cloth, then clip into the brackets on the roof.
And I'm sort of assuming that I would be best to use a contact adhesive to stick the edges up?
I really do need some advice on this, as I have never fitted one before so any help would be greatly appreciated!!!
Thanks everyone, matt
Old Aug 2, 2016 | 08:51 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
Never done it but contact adhesive sounds like a good plan as long as it is not a pour out headlining that will allow the glue though
Old Aug 2, 2016 | 09:21 PM
Mattcortina
Yes it is it has tiny little holes in it- but I was thinking of an aerosole contact adhesive and being a bit careful! Not really sure of what else I could use? Thanks
Old Aug 6, 2016 | 08:15 AM
tay14's Avatar
tay14
Have a look over at
www.buysellcortina.co.uk.
Iam sure some one will help you. I need to fit one to my mk2 as I think the owner was a big Smoker and it looks stained. But it's the original head liner as its a one previous owner car so might try and clean it.
Old Aug 6, 2016 | 08:27 AM
costina's Avatar
costina
Live long and prosper!!
You need this stuff. Its the best many trimmers i know use it.
Put your bars in and then starting from the middle of screens work your way outwards pulling tight and glue over the screen lip. Screen rubber then covers it.
Small brush for glue on both surfaces leave to go touch dry and then stick.
Do sections at a time.
Jack and the Beanstalk
16
Mar 8, 2022 03:15 PM
timsrs
18
May 14, 2016 12:15 PM
gcfcos
May 14, 2016 06:02 AM
matty325
May 9, 2016 06:56 PM
timsrs
Ford Escort RS Cosworth
May 7, 2016 04:09 PM
