Focus RS mk1 smoke changing gear
Old Jul 22, 2016 | 04:45 PM
Blixt's Avatar
Blixt
Default Focus RS mk1 smoke changing gear
I have a problem that I cant find any answer to, search the net for hours...
I got myself a 2004 RS mk1 with 144000km on the odometer.
3" Mongoose, IC Pro alloy, special map since 2004, K&N air filter.
Whit cat on I get smoke when I floor it and change gear, when I de-cat it I get a puff every time I change gear, if I floor it I get a huge cloud.
The former owner did an overhaul on the turbo, made no difference at all.
There is no smoke at start-up, could not be valve seals then?
It has a really bad idle when I have the cat on, stops 1 of 3 times when I hit the clutch for a junction.
If I change gear and support with gas, don't let the revs fall down, then no smoke...
It don't seems to use oil or water, new spark plugs fitted (Denso), cleaned the air filter.
There is a little dent on the oil return from the turbo.
Checked the vacuum pipes for leakage or bends.
The smoke looks blue in the mirror but I'm not sure because of black tinted windows (its not white smoke).
Black soot in the end pipe.
It run like a rabbit on speed, so cant say there is any other fault on the engine.
Anyone with ideas about what to do next?
Sorry for my bad English.
Old Jul 22, 2016 | 06:00 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
The blue smoke is usually associated with turbo problems, oil being burned etc.
Old Jul 22, 2016 | 09:22 PM
bigdel's Avatar
bigdel
My lad's FRS did the same. when we took it to bits you could wiggle the turbo compressor shaft about 2mm either way. Turbo needed a complete overhaul
Old Jul 22, 2016 | 10:22 PM
jc2000e's Avatar
jc2000e
i had similar issues on my old delta integrale years back turbo was screwed.
Old Jul 27, 2016 | 07:32 PM
Blixt's Avatar
Blixt
Thanks for the answers.
But if its not the turbo (the former owner had it totally overhauled) what to check next?
Old Jul 27, 2016 | 09:06 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
I wouldn't rule it out, overhauled or not.
Old Jul 27, 2016 | 09:08 PM
rooos's Avatar
rooos
sorry, i'm not such familiar with turbo issues,
but for n/a i'd say: blue smoke...
-... when start up, after a throttle release+floor it => valve seal or guides,(or thin valve/s),
-...after idling+floor it => piston rings.
you may also have some issues with the crankcase ventilation...
this might be detected running it, in normal condition, with the crankcase ventilation hoses disconnected for a while (not too much, to not to soil the engine bay with oil vapours).
but it could be either a badly overhauled turbo. even good technicians do mistakes...
i apologize for my bad english too.
hope it helps you to find out what it is...
(i'm curious too) keep us posted on this one.
Old Sep 10, 2016 | 07:24 PM
Blixt's Avatar
Blixt
Could these marks on oil return pipe make my car to smoke when changing gear?
Old Sep 10, 2016 | 08:23 PM
jonfoc's Avatar
jonfoc
Those dents won't make a difference. I had a brand new turbo that smoked badly on over run. It's easy to take the turbo off so check it rather than rely on what someone says. Next I would check stem seals
Old May 21, 2017 | 09:11 PM
Blixt's Avatar
Blixt
Problem solved after changing dump valve, no smoke on shifting gear and perfect idle.
Old May 22, 2017 | 05:38 PM
big_wasa's Avatar
big_wasa
The oem ecu does not like dump valves. It's a maf bassed system. The ecu will be dumping in fuel for air that was vented to atmosphere instead of being recirculated.
Old May 22, 2017 | 07:45 PM
Blixt's Avatar
Blixt
What!!!
The car need a dump valve, blow of or what you like to name it otherwise you will kill the turbo.
And it should always on FRS be a recirculated otherwise you will run in to trouble, so that was already checked long time ago before I ran in to this problem.
My answer to my thred was if someone ran in to a simmilar problem this might be a solution.
Old May 22, 2017 | 08:34 PM
big_wasa's Avatar
big_wasa
To add to my post, the Oem ecu does not like atmospheric dump valves for the reasons I've put.
Yes the Rs has recirculating bov/ dump valve call it what you like. Technily you don't "need" one.
So what sort did you change ? Faulty Oem or faulty aftermarket ?
Carlos-Titx
Insurance
Mar 8, 2016 09:43 PM
me81pb
Ford Focus Diesel
Feb 26, 2016 04:46 PM
Will Pedley Racing
Ford Focus ST Parts for Sale
Feb 24, 2016 05:22 PM
