job lot of cosworth engine parts. Pictures added £2250 if gone this weekend
Old Mar 9, 2016 | 08:18 PM
Russ Payne's Avatar
Russ Payne
Default job lot of cosworth engine parts. Pictures added £2250 if gone this weekend
Testing to water and looking to get rid of all the parts below due to taking a break from the cosworth scene...
I have enough parts to almost build 2 engines.
I have one bored and machined block ready to go with pocketed Pistons with new rings, crank and bearings, con rod bolts etc...
2x 205 blocks (1 freshly bored)
2x cranks (1 x std grind and polished)
2x Set of rods
Set of Pistons
Set of pocketed Pistons
2x auxiliary shafts
2wd sump
4x4 sump
4x4 head, Ported 24.5/24.5 (freshly skimmed and guides checked)
2 sets of cams
3 sets of pulleys
T3 turbo
Complete 2wd inlet
Throttle body
Another head, had a lot skimmed off but useable
Set of yellows
3x fuel rails
Distributor
Front cover
Couple inner bottom pulleys
Alternator etc
Modine oil cooler
Cam bearings
Lifting eyes
Alternator
Starter motor
Dipstick
Water pump
Oil pump etc
Other parts included but not pictured
Please contact me on 07969443979 if serious
£2500 the lot
Old Mar 9, 2016 | 09:06 PM
Bart's Avatar
Bart
How much for the wrc spec 4x4 head?
Old Mar 9, 2016 | 09:51 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
You need to list prices please as per site rules
Old Mar 10, 2016 | 06:36 PM
RS200dan's Avatar
RS200dan
What's the condition of the cranks
Old Mar 10, 2016 | 07:07 PM
Russ Payne's Avatar
Russ Payne
One is std/std and just polished
The other is still assembled in the engine so not checked
Old Mar 10, 2016 | 07:12 PM
Bart's Avatar
Bart
How much for 4wd head and whats the thickness please?
Old Mar 10, 2016 | 07:19 PM
Russ Payne's Avatar
Russ Payne
Not splitting any of it, sorry
Old Mar 10, 2016 | 07:43 PM
costina's Avatar
costina
Live long and prosper!!
Russ that is a really a good price someone will get a bargain.
Old Mar 10, 2016 | 07:46 PM
Russ Payne's Avatar
Russ Payne
Cheers mate, a lot of stuff there
Old Mar 22, 2016 | 07:18 PM
Russ Payne's Avatar
Russ Payne
Back up for sale!
Old Mar 26, 2016 | 05:43 PM
siscossie's Avatar
siscossie
3-door moonstone
Is the block that been bored been repaired ?
Old Mar 26, 2016 | 06:43 PM
Russ Payne's Avatar
Russ Payne
Yes it has
Old Mar 28, 2016 | 03:49 PM
Russ Payne's Avatar
Russ Payne
Pictures added
Old Mar 30, 2016 | 05:37 PM
Russ Payne's Avatar
Russ Payne
Bump to the top
Can post
Old Mar 31, 2016 | 07:32 AM
Russ Payne's Avatar
Russ Payne
Will take £2250 of gone this weekend
Old Apr 10, 2016 | 12:00 PM
John ler's Avatar
John ler
Did all this sell ta
Old Apr 10, 2016 | 04:06 PM
Russ Payne's Avatar
Russ Payne
Yes it did
Old Apr 10, 2016 | 04:38 PM
John ler's Avatar
John ler
Shhhhhhi7 thanks , I'll keep looking ta
Old May 6, 2017 | 02:09 PM
T.I.K's Avatar
T.I.K
Any 2wd std. pistons for sale ?
Jay,
Apr 15, 2016 09:34 AM
fakejimmymorgan
Ford Focus ST
Apr 6, 2016 01:12 AM
mk3ste
50
Feb 25, 2016 02:56 PM
mgtkr1
Feb 16, 2016 07:03 PM
3dr cossie
Feb 11, 2016 10:44 AM
