1987 Capri project what engine?
Old Mar 2, 2016 | 12:42 PM
Chriscapri1987's Avatar
Chriscapri1987
Default 1987 Capri project what engine?
I have a 1987 ford Capri and I have chopped and changed my ideas with the engine countless times as I'm just unsure as what to put in her I want a minimum of 200bhp I don't really have a maximum but I want it to be as simple as possible fit and also want it to look the part under the bonnet as I will be looking to show it as for a budget the maximum I'm looking to spend is £2500-£3000 all in so including gearbox fittings ect I have thought about carbing a rover v8 but I doubt think that's the best why to go about it any suggestions would be great
Old Mar 2, 2016 | 03:41 PM
saph in dorset's Avatar
saph in dorset
a simple engine conversion would be the BOA Cosworth V6 from a Granada. these drop straight onto the sub frame I believe and can either use the type 9 or a mt75 converted for the V6.
they have 200bhp as standard and with your budget could maybe get to 230bhp with standalone ecu and new plenum.
Old Mar 2, 2016 | 04:00 PM
JOHNDQ's Avatar
JOHNDQ
Why not keep the front end light and use a Alloy 4 cylinder run a I4 etc see way past 200bhp
Old Mar 2, 2016 | 07:56 PM
Chriscapri1987
Would I need to strengthen the car anywhere? Also what diff would I need to handle the power or do you think the standard will cope with it ( sorry this is my first project)
Old Mar 2, 2016 | 07:57 PM
Chriscapri1987
I would prefer to I must admit I do want to give it the heart it should of had eg v6/v8
Old Mar 3, 2016 | 07:24 AM
saph in dorset
as far as I am aware this is a very common engine that people put into a capri. I think the standard diff is normally used and I would have thought it would be fine. otherwise any sierra diff im sure would fit, again not really sure.
strength wise the car will be fine, as some capris came with a big v6 engine as standard.
there will be lots and lots of information about fitting this engine into a capri available as it has been done many, many times.
Old Mar 3, 2016 | 11:49 AM
PF Ben's Avatar
PF Ben
I agree the Cossie V6 from a Scorpio is a great bet for your power level. Yes you could get that out of a 4 banger Zetec or similar, but the Capri does go well with a bit of broad shouldered torque rather than revvy hp. Well trodden conversion, relatively cheap and will do spaceship mileage if looked after.
Old Mar 3, 2016 | 12:29 PM
costina's Avatar
costina
Live long and prosper!!
2.9 12v or 24v would be the way to go.
diff depends on what spec was originally.
ideally a 2.8 lsd rear axle would be the ticket but they are approx 800 quid now.
If injection you will need a 2.8i capri tank.
Old Mar 3, 2016 | 03:33 PM
Griff51's Avatar
Griff51
Cosworth V6 probably the easiest. If it was me, 3 litre Duratec V6 from an S Type Jag, with Getrag gearbox.
Old Mar 4, 2016 | 06:36 PM
STeve's Avatar
Super Moderator
small block V8, simple mechanics and loads of torque
Old Mar 6, 2016 | 10:43 AM
COLEYST200's Avatar
COLEYST200
It might run but not very good it will over fuel and kill the plugs and it will proboly start putting petrol in the oil so I would not do it . Run it in on wot it had in befor then just take the grays with you when you have it mapped
Old Mar 6, 2016 | 10:44 AM
costina's Avatar
costina
Don't you hate it when the forum does this!!!!!
41
Feb 19, 2016 09:15 PM
Tommy777
Feb 10, 2016 09:46 PM
155lee
Feb 9, 2016 01:01 PM
Yummi
Ford Mondeo Including ST
Feb 6, 2016 05:53 PM
Pinchers-ST
Feb 4, 2016 07:20 PM
