Motorsport developments engine loom for 4x4 Sierra cosworth
Bought one a few months ago and finally found some time to look at fitting it,
Any one done one themselves if so any tips or things to make life easier?
Not that I have removed a loom fully but it would just be a case I guess of removing the lower dash to aid in finding the grommet in the bulkhead and feed to old one through after of course removing the ecu out of the holder and the one I think above it and its cradle which if I remember rightly is held on by a couple of bolts???
And with the new loom labelled up it'll be well easy.
Hope this has been some help
They are nicely labelled up so that bit is easy. Remove the glovebox to give you access to the big grommet in the bulkhead.
Just take your time and keep it as tidy as you can. James (Loomer) said my fitting handiwork wasn't bad but could have done better when I returned to MSD
LOL
This loom makes a huge difference to the running voltage and much reduces voltage drop. When my fans kicked in there was hardly any voltage drop instead of the usual 1v!
You should have received instructions with the loom. I didn't chop any muliplugs but just soldered the wires in your second pic where it said in the instructions.
The wires on that muliplug looked damaged??
That is the connector you need to use, all the feeds you need are in there, just cut the plug off and connect the new loom to it.
or you can wire the new loom to the fuse box and connect directly to the dash display for the gauges.
Green-Tacho- (Car loom Green)
Blue-Engine coolant temperature gauge (Car loom brown/white)
Brown- Oil Pressure (Car loom light brown/green)
Red- switched Ignition feed (Car Loom Black)
The fuel pump relay fuse has a blank output pin, connect to the car loom Black/Red OR to the fuel pump directly, (We advise the use of an inertia switch if running directly)
I have a new fuel pump loom run in but not connected can it be used still if so where should I connect it?
May be bitten a bit more than I can chew! It's a steep learning curve owning a cosworth!!
yes it can be used no problem, you are best just connecting the engine loom up to the OE fuel pump feed which will run down through the inertia kill switch, the fuel pump loom will then take the feed after the kill switch as a trigger in the boot.
If its one of my fuel pump looms, its a small blue cable that you connect to the OE pump power as the trigger.
Hi
i m changing my loom as well
regarding the inside car loom i have:
black
black / red
red/blue... stu told me we do not use it any more
green
brown/white
so 1 wire is missing
for the oil pressure light or the coolant temp gauge
depending the affectation for the brown/white
how do you manage this issue?
thanks for your help
black
black / red
green
brown/white
You may not need to use the oil pressure wire if this is in the chassis loom, you can leave it in used if so. Otherwise if you cannot find the cabling fit it you can pin it out and connect directly to the dash wiring.
You can bell it out from the standard loom and find out which cable it is.
I've just fitted one of James' looms to my RWD Saff.
Very straightforward bar a couple of queries (but I do this shit for a living on oil rigs).
Car fired up first time, no problems so far.
SO i finaly got my new loom.
When removing the old engine loom i find that it was partly connected to the main loom just behinde the glovebox / ECU. And it was stuck. So i was opening the loom to get the wires out, some had connectors running back to the cupe fan area just under the front window, 2 conecctors there. Some was going close to the coil. And some was going to a couple of reelays and a fuse neer the ECU/ glov box. Some off the cables had to be shopped to get it the engine loom loose.
The main feed was behinde the battery so thats easy.
What im wondering is what it all was/ are for? The car had AC and heated windsreen but are that going in to the engine loom form the main loom ?
Any here that knows what are going tru the engine loom? From what i can tell its not just to the engine /coil/ sensors etc.
Its a 92 shapphire from italy
Thanks
Thanks
The heated screen is normally connected to the blue wire of the alternator. I think it should connect from the main loom to the engine loom through the 3 plugs behind the battery, so there should not be an extra connection for this.
I only have the wiring diagram for the 1990 Cosworth and back then there was no factory fitted aircon available. On other Sierra's the factory aircon system connects to the ECU with 2 wires close to the ECU. But all the other Sierra's use a Ford EEC IV ecu and the Cosworth uses a Magnetti Marelli ecu, so it might not work in the same way.
So this is left in the car. Partly cut sice it was going inside the vintage engine loom and was non removabel.
Thanks
Thanks
Any one ?
Was going to here. Under front window
This was inside the engine loom. Glovbox
Have a suspicion that the ECU is dead, nothing happens. The pump runs with the feed straight on the battery. But no relays are activated by the ECU. Have borrowed a L6 ECU I'll try tomorrow to be sure if my L8 is dead or not. No relays is doing anything at all
No luck whit the L6 ECU, no power at pin 20 in the connector, nothing whit the ignition feed straight to tha battery eather. Think i need to whait for my buddy to come home from vacation for some help
bluntys1rsturbo
658
May 3, 2026 10:48 AM
massivewangers
Oct 19, 2017 08:43 AM
kosienutter
Modellers Corner.
11
Feb 19, 2016 09:31 PM
fordsteve77
Escort MK 5 / MK 6
Feb 13, 2016 08:47 AM
