escort van 1.8 TD engine start up
Hi i have just picked up a 1997 ford escort 1.8 TD it has a badly corroded fuse box (i need one for it) But firstly I would like to start the engine without the fusebox in the car, i have gained access to the stop solenoid on the diesel pump under the PATS cover, It has 2 wires going to it. Am i right in assuming that if i run a live and earth from the battery to the solenoid and a start wire to the starter solenoid, that the engine will turn over and start up, I would like to get the motor running and make sure it is OK before i go to the expense of buying all the parts to get it road worthy.
Thanks
Tony
Thanks
Tony
you remember right the stop solenoid needs to be changed from the pats one to a single wire one+ on the top start it up it wont run right if this is the endure engine or the last of the turbo diesel engines it has a ecu
I had to do this on my Mondeo Td when the pats threw a wobble on a Friday afternoon when leaving London to head home for the weekend, and it took me 5 hours to get home on the back of recovery wagon, I was so pee'd, pretty sure someone on here gave me the advice to fix it, I remember having to Hotwire the pats module though, was a right mare, I just went balls deep with the wiring as no one knew how to bypass it, but was still left with a none running engine until I got the solenoid changed and wired up.
The fuse box says 1997 on it so I am assuming it is a 1997 vehicle. Where would I find the ECU if it has one? Can I just take out the solenoid and remove the spring and plunger then refit it just to start the engine? Then to stop it I would have to stall it in gear.
what does the key look like, does the rocker cover say endura on it, if it has a ecu it will be behind the passenger kick panel in the footwell, they don't normally like your proposed modification a new stopswitch is only a tenner fella
