2002 Ford Fusion (UK) Wipers Not Working Properly
Just a quickie, I've had a look around the forum but not found an answer.
The Mrs wipers on her Fusion work ok on normal and fast but on intermittent they don't do a full cycle and stop anywhere on the screen.
Is this likely to be the relay rather than the motor as the wipers are working on the fully on setting?
normally its the internal fusebox with smaller rectangle relays 70a is massive and more suitable for engine running/heavy load etc, consult your drivers handbook for relay location
Yeah I removed the smaller ones too but it still carried on in intermittent mode (as well as it can at the moment). As I said, the 70A one that stopped it knocked out the blowers too, can anyone confirm if this is definitely the one?
the 70amp one will supply more than one circuit so if other things like blowers etc are working from that then it wont be that relay, in the drivers handbook it will tell you exactly what relay controls what circuit
TrevCos
Jan 6, 2016 08:20 PM
Graham S1
Dec 24, 2015 04:18 PM
TrevCos
Dec 13, 2015 03:16 PM
