HELP...low boost and fuel smell
Old Sep 26, 2015 | 11:00 AM
timsrs's Avatar
timsrs
Default HELP...low boost and fuel smell
Hi
I really need some advice on this..
My mate has a mK2 escort with a simular setup as me.
Greens. T34.etc....330bhp
last night car was running perfect, then this morning he come round and the car stinks of fuel and will only pull 22psi ( was pulling 28 before )
It odd, the fuel pump has alway cavitated slightly as he is running a swirl pot but it has not afected it before.
The car i like night and day does not seem to struggle or splutter just low boost with a petrol smell from arount the pump / filter area.
Really lost with it..
If fuel is restricted will the map sence this and cut the boost.
HELP !!!
I cannot see any fuel leaks
Old Sep 26, 2015 | 11:26 AM
timsrs's Avatar
timsrs
Hi
I have just noticed that when you rev the car the boost gauge does not flick round the the "ZERO" it will stay on the - 0.7 BAR ????
It looks like the engine has been getting VERY hot as well.
Thanks
Old Sep 27, 2015 | 09:19 AM
timsrs's Avatar
timsrs
Anyone !
Old Jun 14, 2016 | 09:59 PM
pete241's Avatar
pete241
Hi m8,i had the same problem.
If over heating and not hardly using fuel,its a duff ebay chip in you ecu !
Check you co as when on idle,then bring up the revs in different ways you probly find it leans off to 0 co.
Just get a Co check any where probly show if not its rollers.
Pete
Old Jun 15, 2016 | 07:26 AM
Guinnless's Avatar
Guinnless
Check the fuel pressure and the condition of the regulator as the diaphragm can leak.
Old Nov 13, 2018 | 11:48 AM
dingla rs's Avatar
dingla rs
Wrong threAd
JK12
33
Apr 26, 2021 12:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
