Wanted V band adaptor
Old Sep 25, 2015 | 11:45 AM
Cosnada's Avatar
Cosnada
Default Wanted V band adaptor
Hi,
I need a V band conversion that bolts to the exhaust outlet for a Garret standard T34 (.63) turbo - this has the seal ring and 3 studs for the exhaust flange and exhaust pipe. I think Reyland used to do them.
Cheers,
Scott.
Old Sep 27, 2015 | 08:45 PM
jamie956's Avatar
jamie956
Originally Posted by Cosnada
Hi,
Cheers,
Scott.
I had one made for mine got a flange laser cut then had a V band half welded to it, I think I have the flange drawing somewhere if you want it.
Old Sep 28, 2015 | 12:36 PM
Cosnada's Avatar
Cosnada
That would be cool. I will PM my email address ☺
Cheers,
Scott.
Old Sep 28, 2015 | 10:09 PM
Brocker's Avatar
Brocker
I have a V-Band adapter from my group A Turbo, if you interessted i can take photos tomorrow.
Old Sep 29, 2015 | 03:03 AM
Cosnada's Avatar
Cosnada
Hi,
The more the merrier lol.
The stainless flange is a cracking idea but am interested in other ideas too.
Regards,
Scott.
Old Sep 29, 2015 | 11:15 AM
Brocker's Avatar
Brocker
Let me know if you interessted ..
Attached Thumbnails Wanted V band adaptor-anhang-1-1-.jpg   Wanted V band adaptor-anhang-2-1-.jpg   Wanted V band adaptor-anhang-3-1-.jpg
Old Sep 29, 2015 | 11:36 AM
Cosnada's Avatar
Cosnada
That's kind of what I had in my head - to use the stock flange clamp and weld a V band to it. The other solution actually replicates this except it's all stainless.
The V band I have has the male / female machining in the mating faces to promote a better seal.
Did you have yours made / adapted or did you buy it as is?
Regards,
Scott.
Old Sep 29, 2015 | 11:52 AM
Brocker's Avatar
Brocker
Regards,
Scott.
It comes with my group a Turbo if i buyed it, but i never used the Adapter
Old Sep 29, 2015 | 12:45 PM
Cosnada's Avatar
Cosnada
Trying to match the V band surface of that adaptor won't be easy as it looks like the mating face is not flat unlike most v bands. I would definitely want to use the flanges I have as they have the sealing machine work on the mating faces.
Do you have the exhaust part of the V band that mates to the adaptor?
Regards,
Scott.
Old Sep 29, 2015 | 12:52 PM
Brocker's Avatar
Brocker
Regards,
Scott.
No only the adapter
Old Jan 7, 2016 | 05:30 PM
marky_g's Avatar
marky_g
Fleet Manager
Well i tracked down a replacment CVH from ian at the RS Centre
Time to start ripping the old one out.....few hours on it today
moesin2005
Jan 23, 2022 06:28 PM
rog
Aug 30, 2015 05:32 PM
CrOwSoN15
Aug 4, 2015 06:24 PM
adriansaleem
Aug 3, 2015 11:21 AM
