2wd Cosworth Front Anti Roll Bar options.
Hi guys, so ive curently got a set of Compbrake Compresion struts fitted to my Cosworth, i fitted them as when i fitted the 17" wheels the tyre caught on the front bumper when turning.
But im getting sick of the CompStruts as they knock and make alot of noise in the car and theyve also came loose where the fasten into the bottom arms before
What other options are out there aswell as a standard ARB?
You shouldn't fit a 4x4 arb to a 2wd car. It pushes the wheels forward and makes them touch the arch on the front.
Normally 17" wheels should be ok on a Sierra though...
I have a Escos on fitted to the rear, i didnt know you could fit the front ones, ill looking into that, thanks.
Whats the deal with bladed ones? Do you get much noise off them inside the car?
H13 (28mm) which gave a low caster angle, and H14 (28mm) increased castor angle by approx 1°
The H14 item worked well, so it was carried over to the 2WD Sapphire Cosworth. I've got a new one of some type kicking around my garage for the last 10yrs, and had a feeling it was H14 which would achieve a fraction more castor which was the preferred way.
In answer to the OP, the decent bladed ARB's will start around £600 plus per end. The fronts normally require a separate bracket welding on the underside of the chassis rails, and you'll need to fabricate some kind of mounting to your TCA's. This won't change your dislikes on the comp struts though (noise, or fear of coming loose). So it sounds like a regular ARB and some uprated bushes would be the way to go for you.
Iain
also:
on the rears, fitting the 22mm escos one will give you LOADS of drifting action as it stiffens up the rear a bit too much, but you can use softer shocks unless you are launching all the time
Not necessarily. It depends what springs you use in combination with the ARB. When combining the stiff ARB with soft springs the influence from the arb is much bigger. I run a 21 mm ARB from a Scorpio 24v (couldn't find the 22 mm), and the handling is fine. It's not tail happy at all.
JoeyBoyden
Jan 4, 2024 02:36 PM
rog
Sep 4, 2015 12:10 PM
155lee
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
