Ignition problem
Old Aug 1, 2015 | 02:51 PM
Sjieter's Avatar
Sjieter
Default Ignition problem
Hey, long time since i posted here but i've got a problem recently.
So the old distributor gave up on me last week, sourced another one and found a brand new one!
The seller said i belongs to a mk4 rst, so i installed it and used the same timing as my old distributor.
Just couldn't get it to start.. so i tried max advance and it fired right up!
Used the timing light and even on max advance i only get 8 degrees!!
That's with the vacuum line to the computer connected !
Checked the cambelt timing, spot on.
Can someone tell me what's going on here?
is there a difference between the s1 and s2 distributor as i'm thinking it's an s1 one.
Thanks
Old Aug 3, 2015 | 07:03 PM
Sjieter's Avatar
Sjieter
nobody?
it's doing my head in.. just can't figure it out.
Old and new look identical..
Old Aug 3, 2015 | 08:35 PM
Karl @ FPT's Avatar
Karl @ FPT
Always a pleasure!
Your ignition ECU (Silver one) could be at fault, the MAP sensor fails leaving the timing static, often at 8 degrees.
Old Aug 3, 2015 | 10:31 PM
Sjieter's Avatar
Sjieter
already switched it for another ecu but the problem remains the same.
Guy i bought it of said it was in working condition, still looks like new too.
Still possible that it's not working correct, i'll try to find another one!
Not easy to find one here though
Forgot to mention! when i unplug the vacuum from the ecu (vacuum is plugged, not open) , the timing goes to 3-4 degrees and it does run harsh at that stage!
Old Aug 5, 2015 | 01:46 PM
Red_bull's Avatar
Red_bull
There are different dizzy's and the lead position is different. Are you maybe wrong on the position? Mine is 180 degr turned compaired to what maniak says. However the 8 degr sounds unlogic then
Old Aug 5, 2015 | 09:11 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Different dizzys for a s2?
Old Aug 5, 2015 | 09:47 PM
Red_bull's Avatar
Red_bull
Yep i recently exchanged dissy on mine. Didn't start changed leads 180 degrees and ran directly
DavidK
Sep 27, 2015 02:55 PM
Daniel Howard
17
Sep 26, 2015 12:39 AM
Russ Payne
Sep 25, 2015 08:29 PM
marky_g
Sep 12, 2015 04:26 PM
