track rod end
Old Jun 30, 2015 | 11:29 AM
rammer's Avatar
rammer
Default track rod end
Hi All
Hope someone can answer this one I have a track rod end severely worn and I am in the process of changing it, I released the lock nut 1/4 turn, counted the amount of turns (20) to remove the old track rod end , on placing the new one I counted 20 turns but it is 2 turns short of the lock nut, Is this in the correct position and do I tighten the lock nut to the new one, I will get the tracking done but not for another month when back in UK any advice please
Rammer
Old Jun 30, 2015 | 03:32 PM
focusv8's Avatar
focusv8
Go for a compromise.
1 more turn on the ball joint plus 1 turn out on the locknut.
If the old one was badly worn then the new one won't do any more damage.
If you can use 2 pieces of straight timber and a tape measure you can check/set the tracking yourself
Old Jun 30, 2015 | 04:06 PM
rammer's Avatar
rammer
Thank you for the reply I have now changed both sides n/side was 20 turns and o/side was 25, am I right in thinking that if I adjust them 2.5 turns each it should be central and it should not effect the tracking, can test after as you say
Regards
ossie cossie
57
Nov 21, 2022 10:05 AM
ossie cossie
Sep 21, 2015 05:07 PM
BRAM
Sep 8, 2015 07:11 AM
rsstav
Sep 7, 2015 04:43 AM
rsturbo27
Sep 5, 2015 05:08 PM
