Car won't turn over :(
Hello I hope you can help me I have a 1.3 petrol mk4 fiesta witch I have changed the fuel pump in today but found that after fitting it wasn't the fuel pump but the relay I bridged the relay slot with a wire to see if the pump would fire up and it did so I now know I need a new relay for the fuel pump but after doing this I now have the problem of when I put the key in the ignition the lights come on on the dash I turn the key and nothing not starter motor would engage engine doesn't turn over. Batter is good reading 12v and all fuses are intact could I have popped another relay and if so witch 1 I can't think of anything else it could be. I even disconnected the battery to see if it was an issue with the immobiliser the light on the dash still flashes I can't think of what else it could be
Thanks in advance
Thanks in advance
Light carries on flashing as it does when the key isn't in. I spoke to an aa guy this morning who reckon I could have bridged a live in the whole slot where the relay is and sent a funny down to the ecu and popped it is this a possibility
It's possible. Check every single fuse in the engine bay and interior fuse boxes. I seem to recall there being something funny, like it's a different unmarked fuse that controls the immob, or there is one tucked away on the back of the fuse box or something.
The Underdog
29
Sep 7, 2015 09:49 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
