Diffrence off XR3I 1,6 CVH
Old May 11, 2015 | 06:25 AM
BAI7200's Avatar
BAI7200
Default Diffrence off XR3I 1,6 CVH
HI
Does anyone know what the difference is between a 105HP and a 90HP Escort XR3i.
I know that the 90HP model has a catalyst and the KE-jetronic. BUT what about the rest off the engine, is this the same as the 105HP model.
Is all this a simple matter off chopping off the catalyst and i have a 105 HP engine.
Sorry for any typos, but are living in denmark and haven´t used english in writing in 15 years
Old Jun 22, 2015 | 05:30 PM
AD-RS1600i's Avatar
AD-RS1600i
Originally Posted by BAI7200
HI
I am absolutely no expert but since no one else has replied.. 90hp sounds more like carb XR3s which pre-date the XR3i which came out around 1983 I believe with mechanical fuel injection? I know at the very end of the XR3i life in MK4 guise there was a pure EFI setup which looks very similar to the EFI setup on the later Zetec engine. I am surprised this was down that amount of power against the mechanically fuel injected XR3i but *from memory* late 205 GTi's had a similar revised engine management system and CAT for the new emission regulations post 1991 (?) and were also down on power..
Old Jun 22, 2015 | 06:13 PM
studabear's Avatar
studabear
The mk4 xr3i never had a catalyst fitted in the uk.
Old Jun 22, 2015 | 06:24 PM
BAI7200's Avatar
BAI7200
After some research i found out that the diffrence is in the pistons og head, it´s the leanburn head, and a low compression(8,5:1) and then offcourse the Bosch KE injection(like RST).
mk3ste
Oct 17, 2021 10:09 AM
stephenb4506
33
Oct 2, 2015 06:25 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 08:57 PM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
