MLR quickshift
Old May 18, 2015 | 08:42 PM
RSmark84's Avatar
RSmark84
Default MLR quickshift
Has anyone fit one of their quickshift kits?
http://www.ebay.co.uk/itm/FORD-ESCOR...item5d4e15dd8c
tempted to buy one as I forgot how bad the throw is after not driving the car for many years, and now i'm driving it Its on my mind to buy.
Old May 19, 2015 | 05:53 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Looks the same as the RD one, I used it for years and for the money can't fault it, worth changing the nylon bushes etc. whilst your at it.
Old May 19, 2015 | 07:02 PM
RSmark84's Avatar
RSmark84
Cheers, Dont suppose you could link me to the nylon bushes or have a part number for them? Thanks.
Old May 24, 2015 | 09:39 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Sorry mate I don't, last I bought some was from ebay but it was a while ago.
Old May 25, 2015 | 12:04 PM
RSmark84's Avatar
RSmark84
No problem. I'm going to get another linkage as mine is a bit too sloppy in neutral, So I can buy this aswell and fit both at the same time.
Old May 25, 2015 | 09:33 PM
slimwynn's Avatar
slimwynn
This might help http://www.zetecinside.com/xr2/gearbox3.shtml#linkage
Old May 25, 2015 | 09:55 PM
RSmark84's Avatar
RSmark84
thanks for the link. Im going to get a replacement linkage from Medway RS centre posted to me for £40, plus Ive found the quickshift is £10 cheaper buying via MLR website.
Should be a nice project for myself over the summer, as I plan on cleaning all back and painting it, and making the plastic look as new, and see about fitting new bolts/nuts.
Old May 25, 2015 | 10:02 PM
RSmark84's Avatar
RSmark84
Just a thought, when I take the linkage apart, what and will anything 'fly' out that I may lose? I dont fancy pulling it apart if theres lots of stuff that could cause a concern.
Old Jun 2, 2015 | 07:18 PM
RSmark84's Avatar
RSmark84
Linkage arrived, found out theres 2 springs mounted to some black bushes.
Also heard there is meant to be grease inside. Does this need replacing?
Old Jun 5, 2015 | 08:34 AM
marky_g's Avatar
marky_g
Fleet Manager
Why not go puma linkage that's what I'm doing
Old Jun 5, 2015 | 07:14 PM
RSmark84's Avatar
RSmark84
Na dont want the hassle of drilling holes in the chassis. welding up the old holes etc. Plus the hassle of sorting out a self return mod. i've already got a replacement linkage ready for the quickshift too.
Old Jun 6, 2015 | 09:47 AM
marky_g's Avatar
marky_g
Fleet Manager
I didn't do any welding when I fitted mine
Old Jun 6, 2015 | 10:19 PM
RSmark84's Avatar
RSmark84
Did you just leave the 2 holes as they were, or ram a screw in each of them and leave them like that?
Old Jun 9, 2015 | 07:40 PM
RSmark84's Avatar
RSmark84
Quickshift kit arrived today, didn't know you need a centre punch and a vice to fit it. Bugger. May just get my garage to fit it saves myself buying all the tools needed that I dont have.
Old Jun 10, 2015 | 11:54 PM
simonmcf's Avatar
simonmcf
Keep up posted? Any before or after shots could be good too. Cheers mark
Old Jun 11, 2015 | 12:42 PM
muz's Avatar
muz
Wye Valley Hardcore
I found even with a B&M which does away with the standard self return with its own version was still poor. I had the IB5 self return fitted inside the box and the gear throw is a dream now.
Old Jun 12, 2015 | 07:30 PM
RSmark84's Avatar
RSmark84
Garage has everything now, Quickshift, Linkage and bush kit. Its going to be rebuilt and modified for the quickshift.
Then once they have finished it i shall paint the gear shift rod and the 2 rods.
Old Jun 20, 2015 | 07:40 PM
RSmark84's Avatar
RSmark84
My friend came round and helped me fit the linkage to the car today. Throw is so much better, and no more sloppy stick.
It goes into gears all ok on the driveway with the engine off. But once the engine is running its a pain to find some of the gears, I've yet to find 3rd gear.
I took it out for a quick drive down a couple of roads(40MPH) and what a pain it is to drive, so looks like the linkage needs adjusting at the box end.
Sorted thanks to those who replied to my thread.
Old Jul 26, 2015 | 01:42 AM
mothrs2k's Avatar
mothrs2k
hi mark, i recently fitted an s2 rst gearbox to my fiesta and i am having the same trouble that you mention above ie not being able to find all gears when the engine is running, especially reverse, although 90% of the time with the engine off, i can find all gears nearly every time. did you get to the bottom of the problem? and did it just need adjusting at the 'box end?
thanks
james
Old Jul 26, 2015 | 02:37 PM
RSmark84's Avatar
RSmark84
as above. Drives spot on and can blast through the gears with ease. Tempted to do it to my Fiesta RS turbo at some point in the coming years.
sm
Aug 1, 2006 05:57 PM
Rippers
Oct 13, 2005 08:24 PM
Disabled Account
25
Jul 12, 2005 09:11 PM
Adam Ash
20
Jul 25, 2004 05:35 PM
rs4steve
14
Jul 11, 2004 11:37 AM
