AN and thread sizes for breather fittings on each side of the block ?
Mar 30, 2015 | 04:17 PM
Anyone know which sizes ? Pretty sure it's AN -12 but what threads ?
Mar 30, 2015 | 05:13 PM
Quote:
Originally Posted by
KSA-Cossie
For a WRC breather? the sizes are -10 & -8
Mar 30, 2015 | 05:38 PM
My new breather system is an10 from both sides of the block and rocker cover then an10 return to the sump with a one way valve in the line
Mar 30, 2015 | 06:03 PM
delbee1
For a Bailey mirror image one, I've got the AN fittings on the breather but need to know the thread sizes on the block.
Mar 30, 2015 | 06:04 PM
ajamesc
Which breather mate ?
Mar 30, 2015 | 06:05 PM
KSA-Cossie
Spec r set up like rods. I did have the block thread size as I broght a fitting for my block but it's at marks. I'm sure it was the guy from torques who told me what size it is
Mar 30, 2015 | 06:08 PM
Mar 30, 2015 | 07:23 PM
Mar 30, 2015 | 08:15 PM
Cheers mate, what thread sizes though ?
Mar 30, 2015 | 08:41 PM
The inlet side doesn't have threads, it's a push in fitting. The exhaust side is 3/8 NPT I believe.
Mar 30, 2015 | 09:38 PM
Mar 30, 2015 | 10:04 PM
The easiest way I found was to use a tap and die set . The pipes are the easy bit it's the adapters you need to screw into whatever your using the hoses for that's the pain in the arse . I found no one really knew what the thread sizes I needed were , so had to find out myself
Mar 31, 2015 | 03:35 PM
Piero at X-Power sells the adaptors for turbo side
Apr 6, 2015 | 10:48 AM
Apr 9, 2015 | 08:30 AM
James which 1 way valve did you use for the sump?!
Apr 9, 2015 | 01:09 PM
The inlet kidney box side is as said a push fit, I also thought that the turbo side was a taper thread from memory but I could be wrong!!!
Apr 9, 2015 | 01:22 PM
Toe Knee
I'm not too sure I'd have to get it out the garage and have a look in not too sure when I'll next be there. Mark Sheed will know
original
Apr 28, 2026 05:20 PM
s1cab
Jul 26, 2018 06:11 PM
Red_bull
Aug 9, 2015 08:34 AM
Caddyshack
15
Aug 4, 2015 08:50 AM
