cossie setup where how much what to expect
Old Mar 29, 2015 | 09:22 PM
mark m's Avatar
mark m
Default cossie setup where how much what to expect
cars been sat a good while idles not amazing and and feels generally slow noidea what boost its running
l6 greys t4 rs 500 cooler 205 block what kind of power and what should i expect from a set up? price etc
Old Mar 29, 2015 | 09:31 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
Advising who to take it to depends where you are ?
Old Mar 29, 2015 | 10:24 PM
mark m's Avatar
mark m
West midlands
Old Mar 30, 2015 | 04:13 AM
Staffi's Avatar
Staffi
Tony at Turbo Systems or Karl Norris or MSD are all good Weber mappers, greys are a pretty dated injector now, ( they do their job mind) but there are better injectors around, power around 440-450 they start maxing out.
It would be wise to go and get it all setup, fueling, cold start etc, live map if funds allow are around 400-500 quid iirc.
Hope this helps
Old Mar 30, 2015 | 07:45 AM
cossynut2's Avatar
cossynut2
10 Year Member
Originally Posted by mark m
West midlands
MSD not that far away in Blackpool will get it running right for you.
Old Mar 30, 2015 | 09:23 AM
KSA-Cossie's Avatar
KSA-Cossie
MSD if it was my money.
Old Mar 30, 2015 | 12:04 PM
Staffi's Avatar
Staffi
Yes forgot to add Mark, NMS are in Alfreton, Derbyshire, MSD Blackpool and Turbo Systems Junction 15 M6 iirc just off there.
Old Mar 31, 2015 | 12:34 PM
PF Ben's Avatar
PF Ben
James at MSD did a cracking job with my car and set up, would heartily recommend.
Old Mar 31, 2015 | 02:31 PM
Mk2 escort's Avatar
Mk2 escort
Msd get my vote too, the drive back down the m6 will be fun
Old Apr 5, 2015 | 06:58 AM
mark m's Avatar
mark m
With no trailer msd may be a problem also enquired wait was arouned 6 weeks and don't fancy drive an unset up car that far what's the recommended injector ? Not after massive power would rather air on the side of caution 300/350 would be fine
Old Apr 6, 2015 | 10:22 AM
LHD220Turbo's Avatar
LHD220Turbo
needs a proper live map including cold start etc for a t4, think MSD are around the Ł500 and they will need the car for a few days at least.
to be honest, if you are only wanting 300-350 hp then your car will be horrible to drive on a t4 turbo, better off with a t34. it will be a lag monster on a t4
a t4 is a 500/550hp turbo, but your 205 block probably wont like it!
my advise is sell the t4 and buy a t34, then get it live mapped or go for a decent off the shelf chip
Old Apr 6, 2015 | 06:12 PM
russ rs's Avatar
russ rs
PJ motorsport in wolves used do mine
Old Apr 6, 2015 | 06:32 PM
scoooby slayer's Avatar
scoooby slayer
For 350 hp you need to get rid of the t4, it's pointless lag, ive had 2 proper Rs500 t4 yb motors and the lag is horrendous and only acceptable if running around 500 hp, get a T34. 55 instead for 350 hp and a sensible torque/power curve.
T4 turbos are also wasted on stock port head as it will surge it's tips off above 20 psi, below 5500 rpm ime
Old Apr 7, 2015 | 08:45 AM
mark m's Avatar
mark m
Belive I have a t 04 if this makes much diffrance? Compressor:
-Wheel: 60-1
-Housing A/R: .70
-Housing Style: T04S with 4.00" inlet & 2.50" outlet
Turbine / Exhaust:
Wheel: P-Trim
-Housing A/R: Your Pick of .70 A/R, .84 A/R, 1.00 A/R & 1.15 A/R
-Housing Style: T4 (T04) Housing with 3.00" V-Band downpipe outlet
Center Section:
-Oil & Water Cooled
timsrs
Nov 13, 2018 11:48 AM
Rod-Tarry
75
Oct 13, 2015 04:44 PM
Fezman1
Oct 2, 2015 01:22 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
SMILER258
Sep 28, 2015 09:04 AM
