Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
1.6 Zetec-SE soft tuning
Old Feb 24, 2015 | 09:33 PM
Dripci's Avatar
Dripci
Default 1.6 Zetec-SE soft tuning
Hello to all !
I'm new here and i wanted to share with you my mods. I have fitted on my 2002 1.6 Zetec-SE the inlet manifold from the 1.7 Zetec-SE (*puma donor car) and 1.8 Zetec-E throttle body.
My question is as follows:
Do i have to re-map the PCM for some extra power ? Because i don't feel i gained any torque or power after the changes.
I tested the acceleration and i have the following figures:
best 0-60 miles/h 9.5 s
best 0-100 km/h 10.2 s
80-120 km/h in third 7.4 s
1/4 mile 17.3 s
I don't know what are the standard numbers.. I looked it up and i found multiple figures for 0-100 km/h - 10.7, 11, 11.2 seconds, etc
Did anyone here tried other mods for 1.6 zetec-se ?
Thank you and sorry for my bad english, i'm not from around here !
Cheers !
Old Sep 20, 2015 | 04:03 AM
focuspower's Avatar
focuspower
Hi, as far as your mods no ecu runing will be needed, as the ecu will compensate for the increased air. however a remap such as bluefin could give you some more power.
I'm building a Mk1 Focus 1.6 zetec s with ph3 newman cams, ecumaster piggyback ecu, gsxr 600 itb's and full exhaust. Car currently has ph2 newman cams, full exhaust and bluefin remap runs great. There arw options out there for the 1.6 but just expensive for little hp compared tp bigger engines.
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
sridgett
13
Sep 27, 2015 06:03 PM
focuspower
Sep 20, 2015 03:51 AM
focuspower
Sep 19, 2015 08:27 PM
