How much power can a T5 gearbox handle
Old Jan 17, 2015 | 08:12 AM
3doorcozmess's Avatar
3doorcozmess
Default How much power can a T5 gearbox handle
As per subject. Also who best to rebuild a T5
Cheers si
Old Jan 17, 2015 | 08:17 AM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Cheers si
Its Torque not Power that kills a gearbox. You wont abuse 400ft-lb too many times with a T5 then again drive like Miss Daisy & its fine at 500ft-lb.
Old Jan 17, 2015 | 10:59 AM
cossynut2's Avatar
cossynut2
10 Year Member
Cheers si
Try Bara Motorsports in Birmingham they do a good job.
Old Jan 17, 2015 | 11:23 AM
jontysafe's Avatar
jontysafe
You've also got to take into account tractive effort. This encompasses weight, tyre contact patch, grip and torque.
I have a Cosworth engined Westfield with 205/50/15 medium compound 888s with circa 400lbs/ft of torque and it weighs 630kgs. Personally I think it's easy on its gearbox.
Old Jan 17, 2015 | 11:36 AM
Caddyshack's Avatar
Caddyshack
Well said, loads of torque through grippy tyres, good diff, correct suspension and lots of weight will kill a box much faster than a car that can spin it all away...tractive effort is a great term!
Old Jan 19, 2015 | 03:37 PM
R4N SS's Avatar
R4N SS
mine took over 400lb/ft for years and believe me i tried to break it but it just took it but then again it did like to spin the rear wheels for fun
Old Jan 19, 2015 | 04:52 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
I took 3rd gear out of mine and smashed a diff with a good strong 350 set up. No idea how much torque it had but I was on coil overs and r888's as well
Old Jan 19, 2015 | 05:43 PM
Caddyshack's Avatar
Caddyshack
Yeah, good suspension set up and sticky tyres make a huge difference, those r888s up to temp really do hook up
Old Jan 19, 2015 | 05:45 PM
stevieturbo's Avatar
stevieturbo
C**t
Cheers si
In a 200kg vehicle with 165/60x13 tyres I'd say it could handle 8-900hp
Or did you have a specific application and usage in mind ?
Old Jan 19, 2015 | 05:49 PM
foreigneRS's Avatar
foreigneRS
Testing the future
with an engine speed of 20,000 rpm
Old Jan 20, 2015 | 11:06 AM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
You did the calcs as well .
Old Jan 20, 2015 | 05:32 PM
foreigneRS's Avatar
foreigneRS
Testing the future
educated guess
turbotrev
14
Sep 27, 2015 10:44 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Kam B
Sep 24, 2015 10:40 AM
gingeRS
Sep 4, 2015 06:29 PM
hopper350
Sep 4, 2015 12:53 AM
