What primer after POR-15
Old Sep 24, 2014 | 11:02 PM
FiestaFREAK92's Avatar
FiestaFREAK92
Default What primer after POR-15
Iv piainted the whole underside of my mk2 escort with POR-15, I took the time to do it properly and left it to fully cure for 2 weeks. (Obviously more than enought time required etc) I have sanded down the POR-15 ready for primer.
Now what primer should i use?
I'd like to use 2k but I don't have an air fed mask. So it's 1k I suppose.
Could anyone reccommend a primer to use over the POR-15? I know they do an tie coat primer but Im looking at using a different primer if possible?!
Will it react with the rust preventation? I don't want to be removing all of it off as it took me ages to get to this stage.
Any suggestions helpful
Thanks Scott
Old Sep 25, 2014 | 09:46 AM
3i Jim's Avatar
3i Jim
10 Year Member
All automotive paint is poisonous weather it's 1k or 2k. Use 2k primer, don't use 1k because you'll get all sorts of issues. You can buy a cartridge mask for painting.
Old Oct 2, 2014 | 08:10 AM
FiestaFREAK92
Ok thanks. The process im using is:-
POR15- 2coats applied
1 coat of epoxy maybe 2
2 coats High build
3 coats Colour
Any recommendations on high build primers? ones you've used before?
Old Oct 2, 2014 | 08:33 AM
3i Jim's Avatar
3i Jim
10 Year Member
ICI high build is good stuff. That's what we use at work. It's worth forking out for quality products.
Old Oct 2, 2014 | 09:17 AM
FiestaFREAK92
il look into that, I was contemplating on using Stone guard?! should I use it?
or should I just stick with painting it? its only for the underside I just want to do the job properly.
when would I apply it, after priming it? or before?
Old Oct 2, 2014 | 11:41 AM
3FRD's Avatar
3FRD
Frost POR15 is the best product I've used for underside. I did my Escort Cosworth with this after it was stripped to bare metal. Still looks as good now as it did when it was applied.
Old Oct 2, 2014 | 10:29 PM
FiestaFREAK92
Yeah it's good stuff if done properly! Mines been left for over a month to cure haha and its stuck perfectly fine! Just gone over it with 240 grit to key ready for primer. It's good stuff but its a tad expensive but it does the job brilliantly.
Did you primer over yours?
Old Oct 14, 2014 | 11:52 AM
3FRD's Avatar
3FRD
Best stuff I've ever used, no I never used primer. Just applied to bare metal, sprayed on about 4 coats. It's rock solid and doesn't chip. Not sure why anyone uses waxoil, it sags over time creating water traps, is messy and always minging. In my experience creates more rust than it protects.
Wilsfoci
15
Mar 30, 2016 10:26 PM
Paul_RS
Jan 3, 2006 12:08 PM
RSBen
Jun 19, 2005 07:52 PM
Adz 131
Feb 28, 2005 11:00 AM
666monkey
Jun 2, 2004 04:48 PM
