Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
3 door locking problem?
Old Aug 25, 2014 | 06:57 PM
vtgrrrs's Avatar
vtgrrrs
Default 3 door locking problem?
Wondered if anyone had any ideas or simple fixes? My mk1 3 door focus passenger door will only unlock when I use the key. It won't unlock using remote key fob or when I try and open it from inside.
Once I have opened the door with the key it will open normally and lock normally, but once locked won't open again without using the key.
Old Aug 25, 2014 | 07:26 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
does your remote work ?
Old Aug 25, 2014 | 07:48 PM
vtgrrrs's Avatar
vtgrrrs
The remote works on the drivers door (locking and unlocking it) but will only lock the passenger door but won't unlock it.
Old Aug 25, 2014 | 07:52 PM
GVK.'s Avatar
GVK.
Have you tried pressing the remote twice to unlock the passenger door, some cars are set up to open passenger door on 2nd press.
Might not be the case but worth a check.
Sounds like it's double locked if you can't open from inside either.
Old Aug 25, 2014 | 08:06 PM
mk2grp1's Avatar
mk2grp1
yes try the 2 press unlock. mine locks the car with 1 press and double locks with 2 presses, and 1 press drivers unlock , 2 presses unlocks whole car
Old Aug 25, 2014 | 08:14 PM
vtgrrrs's Avatar
vtgrrrs
Yeah, tried that but didn't work. Very annoying!
Old Aug 25, 2014 | 08:27 PM
vtgrrrs's Avatar
vtgrrrs
OK, very strange but went out and tried it again with two very fast taps and it seemed to unlock it. Not convinced that has resolved it long term as I tried it before and it didn't work. Weird.
Old Aug 25, 2014 | 08:31 PM
GVK.'s Avatar
GVK.
See how it goes, it's how it's been set up to open like that.
PaulinhoT
Oct 28, 2015 06:06 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
Red_bull
Aug 9, 2015 08:34 AM
tankybaby66
Aug 9, 2015 07:13 AM
