Mk2 Escort Brake Problem after upgrade Calipers
Old Aug 6, 2014 | 09:01 AM
v5uk's Avatar
v5uk
Default Mk2 Escort Brake Problem after upgrade Calipers
I have a left hand drive Mk2 escort 1.3 ghir and have fitted Prinsess 4 pot calipers up front with Capri Disks, in preparation for a engine swap
I have also fitted 3 new braided hoses and a couple of brake lines that looked suspect, but now I have very low peddle biting, I have bled the whole system with a power bleeder but its still soft
So I can only presume that I need to swap the servo or master cylinder or both.
Any ideas?????
Thanks Steve
Old Aug 6, 2014 | 10:56 AM
Icurus's Avatar
Icurus
I think you are correct in that you may have to fit a bigger master cylinder, as you are now trying to move 8 pistons as opposed to the 4 pistons in your old calipers, and the 8 might have more surface area requiring more fluid for the same distance travelled?
I'm sure there is a ratio calculator somewhere on the net, or a more knowledgeable person will be along to verify our thoughts
Old Aug 6, 2014 | 11:54 AM
Icurus's Avatar
Icurus
Or you have not bled all the air out!!
If you pump the pedal does it bite higher?
Old Aug 6, 2014 | 11:59 AM
timsrs's Avatar
timsrs
Either air in the system or as i found when i fitted AP's with 4 large pistons the master cylinder needed to be changed.
More fluid was required to fill the bigger pistons, i did have a pedal box with no servo on mine.
Old Aug 6, 2014 | 02:32 PM
v5uk's Avatar
v5uk
Im sure its going to be a master cylinder problem
any ideas where I can get a bigger M/C
Can I pull one off any other kind ford or will it have to be off a Mk2 escort? if so any idea what model coz I thought they all used M16 calipers so wont the M/C be the same????
Cheers Scott
Old Aug 6, 2014 | 03:44 PM
Icurus's Avatar
Icurus
I think its all down to ratio. Have you tried rallydesign? They used to sell Princess 4 pots, so they may know what MC you will require. Have been very helpful over the phone in the past.
http://www.rallydesign.co.uk/
Old Aug 6, 2014 | 04:29 PM
v5uk's Avatar
v5uk
Ill give them a bell in the morning had loads of stuff of them for this car
Cheers Steve
Old Aug 6, 2014 | 04:33 PM
timsrs's Avatar
timsrs
R.A.C.E. in stoke is where i got mine they will advise also
Old Aug 9, 2014 | 08:20 AM
v5uk's Avatar
v5uk
I think I might have got to the bottom of the problem
I jumped in the car the other morning and started the car and pressed the peddle a couple of times and the travel was about half way down and firm every time i pressed the peddle, peddle wasn't creeping up so im sure no air is getting in but I did have the handbrake on so im thinking the rear shoes need adjusting??? I'll try again with the handbrake off before I start to see if the peddle sinks to the bottom when pressed.
Cheers Steve
Old Aug 9, 2014 | 08:42 AM
V6 Ste's Avatar
V6 Ste
Think the RS2000 one is bigger and should do the job or perhaps a 2.8 capri if it will fit.
Old Aug 11, 2014 | 12:17 PM
v5uk's Avatar
v5uk
I have brakes woop woop
Vincereese
Jun 1, 2023 09:14 AM
jason_nike
Aug 18, 2019 10:53 AM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
Aug 10, 2015 12:08 PM
