Fuel pressure problem
Old Jul 29, 2014 | 01:46 PM
MARCOSWORTH's Avatar
MARCOSWORTH
Default Fuel pressure problem
Hi, I've a problem with the fuel pressure under load as it's only rising up to aprox 55 Psi, I've noticed the pressure was low on idle (30 Psi) so I raised the pressure up to what it should be on idle and did I little test drive but the pressure does not come above 55 Psi.
The pump is a Bosch 044 and about 3 years old but sounds "crispy", could it be the pump or the regulator which is a Aeromotive A1000.
What's best to test and how before spending money on new parts?
Old Jul 29, 2014 | 01:54 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
100% it will be fuel regulator mate
Had issues with mine on Dyno and I know Mr Shead @ MA Developments uses them purely as a door stop
I have a spare I can take to Ford Fair I'd you are coming over.
Old Jul 29, 2014 | 02:06 PM
tony66's Avatar
tony66
Default aeromotive fpr
take it apart and you will find the spring broken at a guess
i bought a high powered car from somebody who had a new aero fpr fail[spring]-they sent him two springs....must be confident of their product[not]
Old Jul 29, 2014 | 02:11 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
And they don't like seating properly inside leading to low pressure and inability to increase correctly with rising boost.
Old Jul 29, 2014 | 02:19 PM
MARCOSWORTH
Thanks guys, will open it tomorrow
Not coming to Ford Fair Rich but going to Time Attack the week after at Cadwell Park
Old Jul 30, 2014 | 08:27 AM
MARCOSWORTH
Opened up the FPR, i think i need no words
Old Jul 30, 2014 | 10:08 AM
tony66's Avatar
tony66
Default reg
are you goin to repar or bin it?
i may have a spring somewhere-will have a look if you are-and send dimensions of spring size-well size it should be....
crap item eh?
Old Jul 31, 2014 | 08:17 AM
MARCOSWORTH
If i could get a cheap repair like a new spring i will repair it for the time being
Old Jul 31, 2014 | 08:47 AM
Richie.'s Avatar
Richie.
aka Turbosailorboy
Any friends over to Ford Fair??
Old Aug 14, 2014 | 12:34 AM
HaggisTurbo's Avatar
HaggisTurbo
wow mate that is well and truly beyond help lol
Old Aug 14, 2014 | 07:39 AM
MARCOSWORTH
Yes mate, i had contact with Aeromotive and showed them these pics, they asked me if i was in marine or automotive
Bailes1992
Sep 3, 2015 02:17 PM
mickparky81
Ford Focus ST
Aug 30, 2015 06:58 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
