sick s2 :/
Old Jun 8, 2014 | 05:25 PM
byrno's Avatar
byrno
Default sick s2 :/
Hi all this is my first post so bear with me. Been a huge rs fan my whole life had a capri s and xrs over the years so I decided enough of driving a corolla found a 88 escort rst that had been re shelled seemed a good smooth running gear and mint interior make a long story short I bought it yesterday drove it home (100+ miles) and then the oil light started flickering so pulled in checked the level of oil was where it should be there seemed to be no noice coming from oil pump engine temp perfect then half a mile from home it start to knock mid revs so I take it oil pump failed and and f****d my big ends fml 😢what are my options?? I'm in the west of ireland and roughly what will it cost 2 get her back fighting fit any advice appreciated
Old Jun 8, 2014 | 06:28 PM
Rsturbowayne's Avatar
Rsturbowayne
Roughly the same thing happened to me, Ł4k later and I've got a 2.0 zetec turbo in and if I was you cut your losses now as I'm just going to replace the head gasket on mine after just 250 miles, 1st rst and the last.
Old Jun 8, 2014 | 06:38 PM
byrno's Avatar
byrno
Will a zetec bottom end bolt up to a rs head do you know??
Old Jun 8, 2014 | 06:54 PM
Rsturbowayne
Haven't the foggy, wasn't given that option ?!
Old Jun 8, 2014 | 06:56 PM
CrOwSoN15's Avatar
CrOwSoN15
Ben
Yes, commonly known as a ZVH. Not as simple as bolting it on though. If you're going to the hassle then you'd be better off with a complete Zetec turbo build.
Get it to a reputable tuner and they'll set you straight.
Old Jun 8, 2014 | 08:08 PM
Rsturbowayne
Originally Posted by CrOwSoN15
Yes, commonly known as a ZVH. Not as simple as bolting it on though. If you're going to the hassle then you'd be better off with a complete Zetec turbo build. Get it to a reputable tuner and they'll set you straight.
Hope you have deep pockets bud
Old Jun 8, 2014 | 08:31 PM
byrno's Avatar
byrno
Think I might throw second hand lump in it for now pity engine wasn't long built
Old Jun 8, 2014 | 09:43 PM
byrno's Avatar
byrno
Would it be worth while pulling the sump of replacing pump and shells would the crank need doing
adam151082
Aug 30, 2015 08:34 AM
MadMac
18
Jan 19, 2005 08:15 PM
Phil
18
Dec 29, 2004 05:16 PM
RSCAT
Dec 20, 2004 09:42 PM
Ginge !
46
Sep 30, 2004 08:54 AM
