Matching ecu to engine no.
Hi, this might be a stupid question, I won an rs turbo engine on ebay to put in a mk2 fiesta but still need an ecu! Obviously want to get the right one! How do I get the information from the engine number? Cheers! Bout to be a simple question!
F reg, So you'll want I believe the ECU with red,white and black squares. Not sure on order?
Dont forget you'll need the other ECU as well.
Does the inlet manifold have the knock sensor? will be close to the vacuum for the brake servo outlet.
big_Rad
Sep 15, 2017 09:36 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
