Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
stripped zetec s track car issue
Old Mar 9, 2014 | 07:21 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
Default stripped zetec s track car issue
Hi,
We are running a zetec s track car fully stripped out inside all inner panels removed
problem we have is lift off over steer... turn into the corner just lift off slightly and the back end goes very light power in and it snaps
whats the best mechanical way to overcome this ?
thanks
t
Old Mar 9, 2014 | 07:30 PM
Madgit's Avatar
Madgit
Works and plays on track
Just trying to eliminate the obvious first and work from there so.....
Why do you go in and lift off, surely going in on a balanced throttle will prevent it happening. Or is it your driving style that's causing it? Do you use heel and toe?
Possibly look at tyre pressures and suspension setup, rake, front and rear toe etc.
Old Mar 9, 2014 | 07:40 PM
Straight_4_N/a's Avatar
Straight_4_N/a
Rear alxe spacers work a treat to fix it
And lower tyre pressure in the rears.
Old Mar 9, 2014 | 08:07 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
its on an oval so braking later into the corner is the advantage point ...but tried various methods of taking the corner even under balanced throttle the back still wants to come round .... running yoko 021r tyres ...we have tried a couple of other cars but they would not move in the corner BUT they had the weight advantage ...this one is bare lol
will try the spacers of a lower offset on rears !
thanks
Old Mar 9, 2014 | 09:36 PM
Madgit's Avatar
Madgit
I think your tyre choice may be part of the problem. I haven't tried them but I understand they are more of a wet biased tyre.
Old Mar 9, 2014 | 11:09 PM
Mouse-fsi's Avatar
Mouse-fsi
I can't remember what there called they fit in your front springs there basically a block of rubber if they still sell them they use to fit the block on I think the xr2i unless your shockers are on there way out
Old Mar 10, 2014 | 12:55 AM
Straight_4_N/a
Watch this at around 1 min thats what my back end was like without spacers, It was so bad later in the day I had I blow out on the o/r tyre and didn't even notice till I got back to the pit.
Old Mar 13, 2014 | 08:52 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
Thanks for the replys !
going to try putting lower off set on the rears so will be like spacers !
thanks
t
JoeyBoyden
Jan 4, 2024 02:36 PM
track.focus'd
Aug 12, 2015 05:53 PM
Red_bull
Aug 9, 2015 08:34 AM
RIB1122
Aug 3, 2015 09:20 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
