Ford XR Parts For Sale Only Ford XR parts for sale in here please. Starting a topic requires you to have purchased a gold membership.
CVH/XR2/XR3/XR3i MFi parts list
Old Jan 13, 2014 | 07:11 PM
JasonXR2Racer's Avatar
JasonXR2Racer
Default CVH/XR2/XR3/XR3i MFi parts list
I have this list of parts I have to sell due to moving onto another racecar with Zetec engine
Also have numerous cams, XR3i MFi inlet set up from a 63k car, RS1600i inlets etc
90 spec front bumper in red £50
CVH/XR2/XR3i parts list
XR2 parts
Steering racks (used) x 2 £15 each
Panhard Rod £10
Strut top plates x 3 sets £5 per set
Amber front indicators x2 (New) Near side £5 each
X1 (used) £3
Clutch Cable (NEW) £8
Indicator stalks x 2 £5 each
Clutch Ratchet a pawl (new) £5
Expansion tanks x 2 (Later type) £5 each
X 1 (Early type) £5
Rear brake cylinder (New) £5
Gen Ford gearbox mount used but like new £5
Pair of front tie bar brackets £10
XR3i Parts
Inner CV Joint (New) £10
Front wheel bearing (New) £15
Rear wheel bearing (New) £12
Standard rear Tie bars with new bushes £15
Powdercoated front anti-roll bar with Powdercoated brackets and new Gen Ford bush brackets £60
Ignition switch £10
Dizzy cap (New) £5
Set of relays £15
Pink fuel pump relay with yellow spot (primer) £20
New temp sensor £5
New oil pressure switch £5
Gen Ford fan belt (Short)(NEW) £8
Gates fan belt (New) £7
Motorcraft inlet sandwich gasket (NEW) £9
Exhaust Manifold Gaskets (New) x 2 £5 each
Downpipe gaskets (Bosal) NEW x 2 £5
Recon Distributor (New) £30
Coil (used) £5
Gen Ford Hydraulic lifters x 8 (NEW) £60
Pair of used XR3i driveshafts £25
Pair of used driveshafts missing one inner joint £20
Pair of driveshafts with no joints £10
Clutch release bearings x 3 used £5 each
Cam locating plates x 5 £2 each
Timing tensioners x 4 (used) £4 each
Dipsticks 3 x long and 1 short
Engine lifting eyes x 2 sets £3
Thermostat housings x 3 £5 each
XR3i alternator bracket with swing arm and heat shield £20
Crank shells 1mm oversize (new) £10
XR3i bottom water hose £5
Continental timing belt (new) £5
Gen Ford sump (used) £5
Gen Ford water pump (used ) £5
Outer CV joint (used) £5
Alternator (good used) £15
Lucas alternator (new) £30
Rear bulb holders x 2 sets £10 a set
Clear front indicators (used) £10
Amber indicators (used) £5
Gen Ford clutch cable (new) £15
Gen Ford rockers x 5 (NEW) £30
None Gen rockers x 4 (new) possibly FAI £20
Used Gen Ford rockers x 8 £15
Gen Ford oil caps x 3 (NEW) £8 each
Gen Ford rocker cover gasket (new) £10
Engines
I have for sale the bottom end engine I had built to use in the Classic Touring Cars. It is same spec as an XR Challenge engine but has 1300 pistons fitted to raise compression. It only did 3 laps after having problems which turned out to be a blocked radiator. All this engine needs is a set of 1600 pistons fitting which are supplied (NEW 0.5mm KS pistons). It was built using a standard size dipped block which was decked slightly and bored to 0.5mm oversize, crank checked and balanced along with all moving components. ARP rod bolts fitted. I’m looking for offers in region of £700 for this and it cost me a lot more to have built and then i’ve bought the new pistons at £100. I also have cylinder heads to go with this if required. Be a shame to have it sat around when it could be in a car for 2014
I have my 2011 championship winning bottom end which was fitted to my car after removing the above engine but again developed problems which we found out was the blocked radiator. It has started to detonate on cylinder 3 and 4 as the fuelling must have leaned off as the engine got hot. This engine would be ideal to bore out to 1.0mm oversize and I have a set of used 1mm pistons on rods if required.
I have another block from my first meeting in my Escort which the oil pump failed. Looks liks its had new pistons fitted at 0.5mm oversize. I’ve got inspected the crank as I only removed the pump to see if it had failed and it was smashed to bits. Rest of block is still complete and would be ideal for someone to inspect and/or rebuild for a spare.
Heads.
Got an untouched 81 SM 6090 BRA cross hatch head which came from a 65k C–reg XR2. I know the car it came from as it was a friends who replaced the engine with a Turbo lump. Its still caked in oil etc and has original cam/lifters fitted. Dont think its been slimmed.
Got an 81 SM 6090 ARH cross hatch head. Its bare and came from a lad who did stock rods in a Fiesta. Looks in good cond and is clean.
Also got other heads incl a couple of XR3i FA heads complete
Got lots of other engine parts I’ve probably missed so if you need anything specifically give me a call
Also got a tub of XR2 silly little stuff with switches etc and also some Fiesta door and side glass
If you buy a job lot I’ll do a deal on price
Cheers!
Old Jan 13, 2014 | 09:39 PM
griffo69's Avatar
griffo69
Do you know if the new genuine xr3i clutch cable will work in a s2 turbo ?
Old Jan 16, 2014 | 08:38 PM
b5rlr's Avatar
b5rlr
Interested in all in new xr3 inj parts.
Do you have part numbers ?
Also interested in a sump and Mfi set up if in very good condition.
Old Feb 10, 2014 | 06:47 AM
Fordmad!'s Avatar
Fordmad!
Hi do you have a power aerial for a mk4 xr3i cab?
Old Mar 7, 2014 | 10:04 PM
pikachu's Avatar
pikachu
Hello mate, do you have a XR3i gear knob for sale? cheers.
Old Apr 8, 2014 | 08:19 AM
J_Orr's Avatar
J_Orr
I have PM'd you about some of your XR2 parts.
Old Apr 29, 2014 | 09:40 PM
scubyo's Avatar
scubyo
Have you got the bottom cam belt drive pulley from behind bottom pulley Thanks scubyo
Old May 3, 2014 | 06:18 AM
curt randerson's Avatar
curt randerson
hi their are the oil dip stick the yellow ones and if so how much posted cheers
Old May 13, 2014 | 03:07 PM
J_Orr's Avatar
J_Orr
I could now also do with the indicators for the mk2 xr2 now as well. PMing you again.
Cheers,
Josh
Old May 21, 2014 | 06:41 PM
b5rlr's Avatar
b5rlr
Anything gen ford and new for a mk3 xr3i I will have. Do you have any breather pipes which run of the inlet manifold? Can be used ones?
Thanks rob
steve.rst
Mar 15, 2016 08:01 AM
IainRS1700T
Sep 25, 2015 06:44 AM
jonnyenglish
Sep 21, 2015 07:31 AM
Fudgey
Sep 17, 2015 01:06 PM
stevierob
Sep 7, 2015 07:09 PM
