Ford Puma Discuss the Ford Puma here!
Pollen filters
Old Nov 3, 2013 | 07:16 AM
STeve's Avatar
Super Moderator
Default Pollen filters
My puma came with a full ford stamped history and just 55k so decided to double check standard of service parts etc yesterday and all was good and then opened pollen filter compartment and bloody hell the filter was minging and as heavy as hell, on closer inspection it was rammed with leaf mulsh etc from years of not being changed, bloody good ford dealer they were lol
Old Nov 3, 2013 | 08:03 AM
stu20004x4's Avatar
stu20004x4
mk6 escort fantasist
nice! what are your plans for the puma mate? hows the estate coming on?
Old Nov 3, 2013 | 09:31 AM
STeve's Avatar
Super Moderator
estate has gone stu as another mates need was greater than mine lol, the puma is now my play thing as my capri only gets looked at once in a blue moon and the MG is a family heir loom
Old Nov 3, 2013 | 09:56 AM
stu20004x4's Avatar
stu20004x4
got to be honest i didnt like pumas when they came out, its only since joining here that ive started to apprexiate their curves!
Old Nov 3, 2013 | 10:23 AM
STeve's Avatar
Super Moderator
get behind the wheel of a nice 1.7 and go for a spin and see what you thoughts are after, its surprisingly good and not what I expected at all
Old Nov 3, 2013 | 11:29 AM
SBT83's Avatar
SBT83
Not Crazy, just Unwell
Sounds about right for main dealer to fleece unsuspecting customers! We had a bloke with a series one that had full ford history and he came to our garage as he heard good things and were cheaper than ford. Turned out the plugs had never been changed. 1 snapped in the head, had to use an extractor for it. When we told the bloke he it was taking longer than expected he said he wouldn't use us again and would take it back to ford!?
Main dealer mind control
Not all it's cracked up to be
Old Nov 3, 2013 | 11:46 AM
chris cdti's Avatar
chris cdti
I liked the puma's when I worked at ford. Apart from cracking my head on the a post getting in
Old Nov 3, 2013 | 02:05 PM
STeve's Avatar
Super Moderator
done it myself a few times but after a while you master the puma duck to get in and out
Old Nov 3, 2013 | 02:06 PM
STeve's Avatar
Super Moderator
thats the thing its one of the easiest no tools needed job and it was not done
Old Nov 3, 2013 | 02:12 PM
GVK.'s Avatar
GVK.
Got to blame the 'bonus bashers' who do the jobs too quickly and lob pollen filters in the bin.
I worked at a big city main dealer once, the bins were full of non-fitted service parts.
Old Nov 3, 2013 | 03:04 PM
Dal_'s Avatar
Dal_
Does your Puma have the extra plastic cover above the pollen filter housing? They introduced that to (some of) the later ones as they must have known leaves turn to mush easily down there..
Might be an idea to see if the housing itself doesn't have a split / crack in it as not much moisture should really get in there.
My cossie had a full service history. I changed the fuel filter cause it would cut out and not start again.The date on the fuel filter was 06/1991.
Old Nov 3, 2013 | 03:05 PM
As Steve said go for a drive in one there bloody brill little cars.
Old Nov 3, 2013 | 06:22 PM
STeve's Avatar
Super Moderator
checked all that out Dal as you could see it was old 100% no doubt, perhaps they forgot to look under the cover , but changed the plugs filters and oil and they were all spot on
heres the engine bay and its spotless
Old Nov 3, 2013 | 07:58 PM
chris cdti's Avatar
chris cdti
The nasty cheap thin plastic cover I remember them.
Old Nov 3, 2013 | 08:00 PM
chris cdti's Avatar
chris cdti
Where I worked in vauxhall there was a few of them, they seem to be the same people who don't remove the wheels on a service or use a torque wrench on the wheel nuts
Old Nov 3, 2013 | 08:02 PM
chris cdti's Avatar
chris cdti
The cougar was the same, they should of come with a crash helmet.
Old Nov 4, 2013 | 04:43 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
Check the fuel filter too. Another commonly overlooked service item.
Old Nov 4, 2013 | 06:21 PM
I dont think my fuel filter has been changed before.Its on the to do list.
Old Nov 4, 2013 | 07:07 PM
STeve's Avatar
Super Moderator
yep did that too and you could also tell that was old, but I did open it up as I was curious and take a looksy and it was pretty clean so its happy days really
Old Nov 4, 2013 | 07:36 PM
GVK.'s Avatar
GVK.
Memory not too great but I don't think Ford ever included fuel filters as a service item on the old petrol engines. If so it was something like 60k-72k or whatever.
Old Nov 5, 2013 | 08:00 AM
STeve's Avatar
Super Moderator
I remember seeing lads in the workshops back in the day when I was at ford booking out all the service parts on the back counter for a car and fitting some and binning the rest so it came as no real surprise, since changing the pollen filter at least the air coming into the cabin smells fresh rather than musky
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
stevecfrst1
Sep 30, 2015 05:18 AM
