Audi help please
Old Oct 28, 2013 | 06:21 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
Default Audi help please
Hi quick question my engine blew on my a4 tdi 130 I've found a replacemt but it's from a passat tdi 130 with the same engine code avf. Question is will this be a straight swap with no hassle and not having to change anything thanks.
Old Oct 28, 2013 | 07:12 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
Can anybody help please ??
Old Oct 28, 2013 | 07:17 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
The lump will be the same but you may have to swap over your manifolds? Mounts? Sensors? ETC
Old Oct 28, 2013 | 07:19 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
Ah I was hoping it would just drop straight in might not bother
Old Oct 28, 2013 | 07:20 PM
martynhomer01's Avatar
martynhomer01
AVF engine code denotes that the block etc will be the same, but certain small things may be slightly different, I.e mounting points, inlet manifolds etc
Old Oct 28, 2013 | 07:26 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
Ok so if I still have my old engine between the 2 I should defo be able to get it running without buying anything else ?
Old Oct 28, 2013 | 07:33 PM
martynhomer01
Certainly! All the bolt ons will be interchangeable, so get them next to each other and swap a few bits.... And hey ho!
Old Oct 28, 2013 | 07:34 PM
zippyobrien's Avatar
zippyobrien
You'll need to swap your pump and injectors I'd have though as there coded
scottyrs's Avatar
scottyrs
DURHAM RSOC
Ok thanks mate that's good to know, driving me up the wall having no car lol
Old Oct 28, 2013 | 07:47 PM
jamie's's Avatar
jamie's
pump and injectors shouldn't be coded on a 130
JoeyBoyden
Jan 4, 2024 02:36 PM
Oranoco
41
Feb 11, 2016 01:28 PM
Oranoco
12
Oct 2, 2015 02:18 PM
Eigdoog
48
Sep 19, 2015 11:03 AM
M K
Aug 12, 2015 06:57 PM
