Bmw x3 2.0d e83 '2006 'limp home mode'
Old Oct 27, 2013 | 09:37 PM
D770 BBC's Avatar
D770 BBC
Default Bmw x3 2.0d e83 '2006 'limp home mode'
Lack of power around 40mph 2500rpm any ideas ??
Old Oct 27, 2013 | 09:47 PM
bigjohn0's Avatar
bigjohn0
It could be anything really going on the description. You need to plug a code reader into it mate and that will tell you whats going on with the car.
Old Oct 27, 2013 | 10:11 PM
D770 BBC's Avatar
D770 BBC
Had the problem before and it came up with dpf, pressure sensor, maf, egr, glow plug. Since then the glow plugs have been done and it ran great. Now it's worse......fearing dpf
Old Oct 28, 2013 | 08:39 AM
Caprigirl's Avatar
Caprigirl
Drift Queen
You need to get the codes read by someone who can interpret them . If it is a DPF fault you might be lucky and get a forced regen
Old Oct 28, 2013 | 09:53 AM
D770 BBC's Avatar
D770 BBC
That dpf fault comes up every time, but sort something else an all fine, then leave it a few months and problem again! My mates got several systems to read em, but so many faults show up
Old Oct 28, 2013 | 07:56 PM
D770 BBC's Avatar
D770 BBC
Yep dpf again !!! Decided to get it removed and remapped
Any advice on the matter ?
Old Oct 28, 2013 | 08:02 PM
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
I had this before customer spent over Ł1k on parts and the problem was still there so I took it out in the rain and turned off the traction control and it kicked up the abs light, came back and plugged it in and it was throwing up a wheel speed sensor which was causing it to going into limp mode, what warning lights come up is it the warning triangle?
Old Oct 28, 2013 | 08:04 PM
gingerturbo
Lol^^^rushed in without reading it all^^^
Old Oct 28, 2013 | 08:06 PM
gingerturbo
Make sure they don't actually remove the dpf, only the internals as it needs to be visible
Old Oct 28, 2013 | 09:41 PM
D770 BBC's Avatar
D770 BBC
Haha yeah I knew that. Just gonna smash out that pile of crap inside and remap
That's the thing with it all is that no lights came up not even eml
Old Oct 29, 2013 | 06:02 PM
D770 BBC's Avatar
D770 BBC
Finally !!! Removed dpf and smashed out the innerspring which were rammed solid full of carbon deposits ! Almost a totally blocked exhaust. Took it to tuned and styled for dpf delete and remap and WOW !! Unbelievable power and response from it, best its ever been
D770 BBC's Avatar
D770 BBC
Inners* not innerspring
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Oranoco
12
Oct 2, 2015 02:18 PM
DAZZER
Sep 30, 2015 08:43 PM
stevecfrst1
Sep 30, 2015 05:18 AM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
