FAO karlos g..... Black top inlet
Old Aug 6, 2013 | 03:44 PM
rsmark86's Avatar
rsmark86
Default FAO karlos g..... Black top inlet
Can't try the blacktop zetec on my inlet as it doesn't fit in a fiesta rs turbo engine bay
So for reference anyone doing a zetec turbo in a frst the black top inlet doesn't fit
Gutted back to the drawing board
Old Aug 6, 2013 | 04:14 PM
rhinopower's Avatar
rhinopower
You have to unbolt from the engine mount. Pull the engine forward to get enough space to bolt it on then push it back. I've got that manifold fitted to my mk3
Old Aug 6, 2013 | 06:07 PM
Karlos G's Avatar
Karlos G
Balls Deep!
There you go Mark, try that! lol
If there is a lot of engine movement it still might hit though?
Old Aug 6, 2013 | 06:12 PM
SBT83's Avatar
SBT83
Not Crazy, just Unwell
Lump Hammer --> bulkhead = Good fit
Old Aug 6, 2013 | 06:18 PM
rhinopower's Avatar
rhinopower
I guess it depends how the engine is mounted. I'm
Using a blacktop side mount to its pretty solid!
Old Aug 6, 2013 | 06:49 PM
rsmark86's Avatar
rsmark86
It's butted up tight against the brake balance bar so no good
I'm bolting my rs1800 style one back on as its modded already for top feed injectors, just needs a lick of paint
One good thing is I just cut all the brackets off for bonnet catch supports as the turbo didn't fit between rad and manifold and now I've moved my rad so far forward I have 3/4"s between the 4x4 cossie turbo and my big alloy rad, so chuffed, just got to make some brackets up
And weld my 3" down pipe into the system
Making loads of progress now
Old Aug 6, 2013 | 06:56 PM
rsmark86's Avatar
rsmark86
And with it touching the brake bar it wouldn't sit flat on the head either
Kyle Langford
27
Aug 5, 2019 07:54 PM
Porplus12
Sep 10, 2015 07:20 PM
TrevCos
Modellers Corner.
Aug 24, 2015 09:31 PM
Aug 20, 2015 09:21 PM
gingerturbo
Aug 11, 2015 09:44 PM
