1.6 cvh non turbo
Old Jul 18, 2013 | 10:57 PM
Widelow'd's Avatar
Widelow'd
Default 1.6 cvh non turbo
i know i wont get massive power but i wanna build a lairy non turbo what do you think is the best route feed back appreciated...
Old Jul 18, 2013 | 11:48 PM
rsmark86's Avatar
rsmark86
go see wayne at wpe (wacky performance engines) in croydon he got my last cvh to do 163bhp on twin dcnfs at nearly 8000rpm, it was wicked...
if it had 45 dcoes and a better exhaust sytem it would have seen 180+bhp and 8500rpm easily
so quick list
high comp pistons
steel rods
lightened and balanced bottom end with arp bolts and pocketed pistons or fit
high comp pistons /steel rods for reliablilty
phase 4 n/a cam
solid lifters
double valve springs
twin 40s
h&h ignition
head worked by wayne
and engine assembled and set up by wayne with a decent exhaust manifold and system should be around 150bhp but with steel internals and the comp ratio around 11.5.1 you could see around 160+bhp
or ported head, cvh33 kit, and twin 40s and 4-2-1 manifold will see a nice 130bhp and a decent dizzy from h&h will make all the difference
Old Jul 19, 2013 | 01:15 AM
Widelow'd's Avatar
Widelow'd
Thanks that's allot of my questions answered..... What kind of money do you reckon I'm looking at??
Old Jul 19, 2013 | 06:19 AM
XR2's Avatar
XR2
The bottom end - maybe. But the cylinder head sure would have been upset. High revs combined with solid lifters and double valve springs are far more than the CVH was designed for. At around 8k and more the rocker bolts will be pulled out of the head along with the thread.
Will end up like this (what happened around 7k!):
Old Jul 19, 2013 | 10:05 AM
haz87's Avatar
haz87
Not always, plus it can be sorted with helicoil or timeserts. I know Marks was an 8k+'er (dont know if he'd helicoil'd or anything) and my previous CVH was an 8k+'er and the rocker posts were untouched (yet on a previous head i'd ripped them out at 6k,lol) so its down to luck tbh. My limiter didnt come in till 9k and i did hit it a few times before i decided to lower it a tad
Old Jul 19, 2013 | 12:57 PM
rsmark86's Avatar
rsmark86
They were modified as I brought it from a championship race car that was running 185bhp at 8500rpm hence knowing what it was capable off
When I got it it had dropped a valve so Wayne re-cc'd it and brought the compression down from 13.1 to 11.4 and rebuilt it all and tuned it.
It did snap a brand new solid lifter when the new owner brought it and new mans gave him a complete brand new set as they believed it was impossible
I did talk to him when I sold it about roller rockers but so far not needed
Old Sep 6, 2013 | 08:37 PM
Kingabe's Avatar
Kingabe
Just bought myself a nice xr2 with,
New pistons
All bearings
Lightened & balanced bottom end
HP oil pump
Twin 40DCOE's
Kent cam
Port matched head
Magnex manifold and stainless steel system
Set up and rolling roaded at 130.8bhp
And it's plenty for now. The cars so light but its not really about the speed or power, the noise of the Twin 40s is bliss. A squirt in 2nd through town makes people jump against the walls! Only down fall is its probably good for 25mpg on a good run!
Old Sep 7, 2013 | 08:43 AM
theheap's Avatar
theheap
Mine will rev past 8k and its all standard apart from the exhaust and filter.
Mind you it is now noisy as fook and every bearing and lifter is knocking like a bitch.
Do I put the 1.4 back in and rebuild the 1.6 or do the zetec thing and still build the 1.6 but a turbo. Hmmm
Old Sep 7, 2013 | 05:13 PM
Kingabe's Avatar
Kingabe
Do these still pull produce at 8k?Must need a lot of money spent. obviously mines setup to produce peak power at 6250 so revving or trying to rev past that would be pointless and probably immediate death!
Old Sep 9, 2013 | 08:52 AM
theheap's Avatar
theheap
I could only ever get 70 tops in 3rd but over several weeks on the same stretch of road I have gain some pace. I now get 85 out of 3rd and have achieved this by simply standing on the throttle for at to long just to see how far I can push it on stock internals. Rev counter used to see no more then 6600 now say past 8000.
Engine is now knocking like a bailiff lol. Mind you I done 150 round trip in it yesterday and it seems to rev and pull a lot easier. Still fooled and will be rebuilt soon
Old Sep 9, 2013 | 10:14 AM
Rogeyboy's Avatar
Rogeyboy
My old NA Cvh on standard ford efi, produced 130bhp with a cam, superchip, exhaust and filter. More to come from a more wild cam and mappable ignition the tuner said. A ported head wouldve been good too, but i found out about these "snails" people bolt on to the exhaust manifold... Makes it a damn sight faster lol!
Old Sep 9, 2013 | 01:48 PM
theheap's Avatar
theheap
Snails?
Old Sep 9, 2013 | 01:52 PM
SBT83's Avatar
SBT83
Not Crazy, just Unwell
Originally Posted by theheap
Snails?
Turbo
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
Jerry Ryan
Sep 2, 2015 08:02 PM
kevin36
Sep 2, 2015 06:24 PM
