mk4 escort cab
Old May 31, 2013 | 09:07 AM
no1birdman's Avatar
no1birdman
Default mk4 escort cab
hi,got a mk 4 1986 escort cabriolet ,years ago fitted a 1600 diesel to it, now need a new engine and cant get one, which petrol engine can i put in, not a fuel injection one as i changed the tank and pulled most of the wireing out for the diesel, i dont want a 1800 diesel engine as the costs of cambelts etc, and been 64 years of age want to replace it with a small engine i can easily fit and maintain. i would not mind a 1100 or 1300 engine petrol or even a diesel, Only going to do it all up and use very occasionaly has ive had the car 20 odd years.thank you
Old May 31, 2013 | 09:52 AM
liam-rst's Avatar
liam-rst
shit happens
Your going to need to change tank anyway if its had diesel in it mate, personally id go for a silvertop zetec as its an easy enough conversion and reliable but if your intent on non injection then id go with a carb 1.6 cvh as found in xr2 and the like
Last edited by liam-rst; May 31, 2013 at 09:53 AM. Reason: because im a spak who cant spell
Old May 31, 2013 | 01:00 PM
no1birdman's Avatar
no1birdman
hi, xr2 is ok but its finding one,
Old May 31, 2013 | 02:07 PM
liam-rst's Avatar
liam-rst
shit happens
http://www.ebay.co.uk/itm/Ford-Escor...item4ac4d38f46
Old May 31, 2013 | 03:06 PM
no1birdman's Avatar
no1birdman
thanks, its got nothing with it, ie starter,alternator manifold etc, but thank you for looking, would a 1.4 escort engine fit the gearbox, and can u pull the engine out of a cab without removeing gearbox, i did not last time but dropped everything with suspension, it neads a new front piece so thought of cutting it all away, pulling engine out through the front if it will cleargearbox shaft, im sure i pulled one out years ago and left gearbox in, thanks again
Old May 31, 2013 | 04:08 PM
jamescosworth's Avatar
jamescosworth
ive just stripped a mk4 xr3i cab of all the running gear, tank etc to drop into my escort bonus....all of my 1.3 engine, gearbox, loom, tank etc is available if your interested and id let it all go cheap just to get it out the way...bonus has only done 58k starts first time runs sweet! inbox me pal if your interested would be perfect for you plans
Old May 31, 2013 | 04:13 PM
jamescosworth
also forgot to add ive got some good doors, bootlid and other bits and bobs off the cabby if you need anything
Old May 31, 2013 | 04:38 PM
no1birdman's Avatar
no1birdman
is a escort bonus fuel injection and would it need a ecu to run,thanks,
Old May 31, 2013 | 05:14 PM
jamescosworth
replied to your inbox mate
Old May 31, 2013 | 08:49 PM
studabear's Avatar
studabear
The cambelt kits should be pretty cheap these days, iirc the interval was 36k or 5 years so If you did fit a 1.8 diesel you could do the belts while the engine was out the car, then your good to go for a while.
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
Chopshop85
Sep 12, 2015 06:42 PM
imnoteasy
Sep 7, 2015 09:26 PM
chris m1
Sep 7, 2015 08:02 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
