Brazing anyone in the know!!
Old May 19, 2013 | 10:59 AM
doga-ot's Avatar
doga-ot
Default Brazing anyone in the know!!
I can braze copper but i need to adapt one of my power steering pipes as its to long so what i would like to know can i cut it to length i need and braze back together using my superfire torch with mapp gas and brazing rods for steel? Pipe is i think 3/16
Old May 19, 2013 | 11:03 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
I twisted the rack to pump pipe on my saff and a second hand one was loads of money so chopped it and brazed a section of copper pipe in it never had any probs with it
Old May 19, 2013 | 11:20 AM
doga-ot's Avatar
doga-ot
Yes but what did you braze it with as i only have my superfire torch with mapp gas ideally i would use oxy acetylean
Old May 19, 2013 | 11:26 AM
ajamesc's Avatar
ajamesc
No idea mate sorry! I used the cutting torch in the workshop with a brazing nozzle on it and we have a box of brazing rods with an orange flux coating on them
Old May 19, 2013 | 11:47 AM
doga-ot's Avatar
doga-ot
Yeah bud got the correct brazing rods but wanted to know if i can do it with a superfire torch with mapp gas
cabriolet's Avatar
cabriolet
remember brazing is omly glueing together the parts with brass as long as it gets proper hot it will work
Old May 19, 2013 | 11:59 AM
ajamesc's Avatar
ajamesc
if it gets hot go for it lol only thing I found is it takes far longer to heat the steel than the copper so easy to melt the copper
Old May 19, 2013 | 12:07 PM
doga-ot's Avatar
doga-ot
I'm not using copper i going to cut it down to size swage one side put other bit inside then braze together with multi purpose rods for (mild steel,stainless steel,copper)
Old May 19, 2013 | 12:11 PM
pee vee's Avatar
pee vee
Give it a go mate. Might take some heating using map gas. But should get there in the end.
Old May 19, 2013 | 12:12 PM
ajamesc's Avatar
ajamesc
I get you mine has about a 4 inch long section of copper pipe in it
Old May 19, 2013 | 01:07 PM
BRIGSPORT's Avatar
BRIGSPORT
UNAUTHORISED DEVELOPMENTS
I have bodged various things together using silver solder and flux with a turbo torch.
Old May 19, 2013 | 08:44 PM
doga-ot's Avatar
doga-ot
Sorted was a piece of piss
Old May 19, 2013 | 10:41 PM
BRIGSPORT's Avatar
BRIGSPORT
Take your time, and make sure all surfaces are clean, and it will be a piece of piss. My brazes have to withstand 42 bar, never had a failure yet.
Old May 20, 2013 | 04:54 PM
pee vee's Avatar
pee vee
Work with 410a mate?
Old May 20, 2013 | 05:44 PM
BRIGSPORT's Avatar
BRIGSPORT
I did when i had a job!
Old May 20, 2013 | 06:57 PM
pee vee's Avatar
pee vee
Bugger. If you ain't got a job in a few weeks time,
Pm me. I might be able to help.
Old May 20, 2013 | 07:00 PM
BRIGSPORT's Avatar
BRIGSPORT
Ok mate cheers, i am a looooooooooooooooooong way from you though!
Old May 20, 2013 | 07:07 PM
pee vee's Avatar
pee vee
So is the (possible) job lol
I'm sat in a hotel on the east Lancs road as I type this
Old May 20, 2013 | 09:07 PM
BRIGSPORT's Avatar
BRIGSPORT
Ok. Cool. I have my cv ready and waiting.
Mk4 Rick
Apr 26, 2014 02:19 PM
ajamesc
14
May 8, 2012 08:06 PM
johnyjn
Jan 29, 2012 02:52 PM
SillyFezzaMk1
20
Jul 22, 2010 11:52 PM
